UMS 2.6.4 - Unable to play MKVs
thetallest
Post by thetallest »
I have two MKVs that I am unable to play on UMS. These are the first two files I have attempted to play using this program.
Debug logs for both files are attached. Below is the MediaInfo. These are both files ripped from BluRay using the latest version of MakeMKV.
EDIT: Forgot to mention that my Mini's fan goes full blast whenever the UMS tries to stream files to the PS3. Is that normal?
"Michael Clayton" (Error message: Data is corrupted)
Video
Format : VC-1
Format profile : Advanced@L3
Codec ID : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint : Microsoft
Duration : 1h 59mn
Bit rate : 16.2 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.325
Stream size : 13.5 GiB (94%)
Language : English
Default : No
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 1h 59mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 549 MiB (4%)
Title : 3/2+1
Language : English
Default : Yes
Forced : No
War of the Worlds (2005) (Error message: "This content cannot be played. (8002288E1)")
Video
Format : AVC
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=3, N=12
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 56mn
Bit rate mode : Variable
Bit rate : 27.5 Mbps
Maximum bit rate : 37.0 Mbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.553
Stream size : 22.4 GiB (87%)
Language : English
Default : No
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 56mn
Bit rate : 1 510 Kbps
Bit depth : 24 bits
Stream size : 1.23 GiB (5%)
Title : 3/2+1
Language : English
Default : Yes
Forced : No
MACHINE:
2011 Mac Mini
Processor 2.7 GHz Intel Core i7 (Dual Core, I believe)
Memory 8 GB 1333 MHz DDR3
Graphics AMD Radeon HD 6630M 256 MB
Software OS X 10.8.3 (12D78)
ums_dbg_waroftheworlds.zip
debug log for War Of The Worlds
(12.89 KiB) Downloaded 619 times
ums_dbg_michaelclayton.zip
debug log for Michael Clayton
(10.71 KiB) Downloaded 583 times
Optimus_prime
Re: UMS 2.6.4 - Unable to play MKVs
Post by Optimus_prime »
Welcome to the forums thetallest. I will get around shortly looking into your bug post.
Edit: If you playing .mkv's to your PS3 it has to transcode them. Not sure what/why your problem is playing those but i may need a little help from some more experienced guys, Subjunk, Anyone????
thetallest
Anyone?
Optimus_prime
Can you give the 3.0.0-a1 alpha build a try, and tell us the results
unific
Post by unific »
I have the same problem started at 2.6.3, 2.6.4 and 3.0.0-a1 - Went back to 2.6.2 all worked again hope you find a solution soon .
sanjeev
Post by sanjeev »
This is same as this thread - ( viewtopic.php?f=9&t=886 ) I tried a lot of options but nothing works.
We really need a fix :), this has become a big problem.
