When using PureVPN Or any VPN the PS3 will stop playing
When I use PureVPN, it will stop any video streaming from my PC to PS3/.PS4. How do I configure it to allow VPN to work while still allowing media to stream to the PS3 to the TV?
Re: When using PureVPN Or any VPN the PS3 will stop playing
Probably VPN app blocks local connections or ports, you can try OpenVPN gui, if it doesn't help you might need to configure static routes in your home router
does this vpn only work in the UK? I want to use it from other countries, is it possible?MickelC wrote: ↑Thu Aug 24, 2017 1:57 am I have used purevpn with kodi and PS4 but it was working fine. May be some thing happening because of your location. If you are located in UK or near around you can opt for the best uk vpn service available. There are a number of vpn provider provider offering free trail service. you can cease the opportunity and try it out.![]()
