replacing UMS FFMpeg version [SOLVED]
Miklos
Re: replacing UMS FFMpeg version [SOLVED]
Post by Miklos »
Thanks for your suggestions, Sami32
With the FFMpeg 2.8.1 in situ I tried all 3 renders and got back an EMPTY message when opening the folders on my Marantz machine.
Swapping back to the original renderer - I got direct access to WAV, FLAC + Mp3 without any problem + access to AIFF via TRANSCODE.
It may not mean anything but for all 3 'test' renderers the logo showed a Sony icon (attached)
Screen shot 2017-01-25 at 18.18.05.png (41.59 KiB) Viewed 4451 times
rather than this which appears with the earlier renderer
Screen shot 2017-01-25 at 18.32.33.png (26.2 KiB) Viewed 4451 times
This is the 'original' renderer:
Marantz-NA.conf.txt
(422 Bytes) Downloaded 494 times
Cheers
miklos
Miklos
Post by Miklos »
Don't know if this adds to the details:
Screen shot 2017-01-25 at 18.48.13.png (47.45 KiB) Viewed 4451 times
I have carried out a fresh log with the set-up of FFMpeg2.8.1 + the 'original' renderer:
(23.42 KiB) Downloaded 503 times
Cheers
miklos
