[SOLVED] UMS cannot play many vids, serviio can!
ex2j
Post by ex2j »
Hey UMS Team,
i prefer ums but i have lots of vids where ums show an error instead of playing. Serviio can play the same file.
For example zoomania at my attached debug log. What do i wrong?
ex2j
Re: UMS cannot play many vids, serviio can!
Post by ex2j »
while uploading there is the error:ERROR
Sorry, the board attachment quota has been reached.
here is a link to my ums_dbg.zip
http://workupload.com/file/4WDmbqP
Sami32
Post by Sami32 »
Hello ex2j,
Add this renderer into your \Universal Media Server\renderers folder:
Samsung-9series.conf
(2.53 KiB) Downloaded 724 times
As it was quickly made just for testing purpose, feel free to upgrade it and submit your work to our communauty.
https://github.com/UniversalMediaServer ... figuration
http://www.universalmediaserver.com/faq ... erSupport1
Hoping that did helped ;)
ex2j
Post by ex2j »
Zoomania works now and lots of other movies too! thank u for that =)
I tryed Slumdog.Millionaire and it starts but has to load every few seconds. unwatchable.
here is my new log
http://workupload.com/file/3v9svyG
Sami32
Post by Sami32 »
Try with that one:
(3.12 KiB) Downloaded 622 times
That's said your audio/subtitles configuration are incorrect. Have a look at your Wiki:
https://github.com/UniversalMediaServer ... -Subtitles
Since your renderer is only seen on your network at the HTTP level only, i don't really know which TV model you are using. KS9000 ?
ex2j
Post by ex2j »
I am using a KS9590 i think in US its called KS9500
ex2j
Post by ex2j »
i replaced the render file.. now slumdog millionair works fine but zoomania doesnt work anymore :D same as before....
http://workupload.com/file/QeQb33Q
when i click on my tv renderer, it seems to you die config file: samsung-CD.config
[TV] Samsung 9 Series (65)
192.168.178.29
uuid:aa54de66-0ecd-4936-bd2f-c7b4c381f4f5
Samsung Electronics
UE65KS9590
AllShare1.0
Samsung TV DMR
it is possible to force a config file for a renderer?
Sami32
Post by Sami32 »
Try that one:
(3.66 KiB) Downloaded 622 times
Nice, that time your renderer send its identity at UPnP level as well, or at least it was received.
It's why it triggered/switched to the Samsung C/D renderer and you loosed the ability done by this renderer, as i didn't have the UPnP informations to implement a recognition at that level.
Yes. But i hope that now it will be fine without doing this.
To force a renderer as default, just follow our Wiki ;)
Go in the "General Configuration" tab and select "Force default renderer..." and select the one you want in the "Default renderer when automatic detection fails" line.
Of course, you can also just select that renderer in the "Select renderers" list.
Enjoy.
P.S. Please, take time to give feedback 8-)
ex2j
Post by ex2j »
it works =))) Good Job and thanks alot!
UMS select automatically the right(your) renderer.
One last thing :D i have a movie (dr strange) that cannot be rendered from ums or Serviio or anything else that i tryed. VLC @my PC/Laptop works. Do you know why?
here are the log when i try to start dr strange:
http://workupload.com/file/cuM7VN9
