Missing MediaInfo
vfr_nz
Missing MediaInfo
Post by vfr_nz »
After a clean install on both LinuxMint 15 (32 and 64 bit) UMS is unable to
find "zen", libzen.so and "MediaInfo", libmediainfo.so.
Both these libraries are installed.
UMS boot log
06-10 19:59:45 Starting Universal Media Server 3.0.0-a1
06-10 19:59:45 Based on PS3 Media Server by shagrath, copyright 2008-2013
06-10 19:59:45 http://www.universalmediaserver.com
06-10 19:59:45
06-10 19:59:45 Build: efdb614c7 (2013-05-15)
06-10 19:59:45 Java: 1.7.0_21 - 64bit - Oracle Corporation
06-10 19:59:45 OS: Linux 64-bit 3.8.0-19-generic
06-10 19:59:45 Encoding: UTF-8
06-10 19:59:45 Memory: 682 MB
06-10 19:59:45
06-10 19:59:45 Working directory: /usr/lib/ums-3.0.0-a1
06-10 19:59:45 Temp directory: /tmp/universalmediaserver
06-10 19:59:45 Logging config file: /usr/lib/ums-3.0.0-a1/logback.xml
06-10 19:59:45 debug.log: /tmp/debug.log
06-10 19:59:45
06-10 19:59:45 Profile directory: /home/wayne/.config/UMS
06-10 19:59:45 Profile path: /home/wayne/.config/UMS/UMS.conf
06-10 19:59:45 Profile permissions: rw
06-10 19:59:45 Profile name: Mint-15-64
06-10 19:59:45
06-10 19:59:45 Error loading libzen: Unable to load library 'zen': libzen.so: cannot open shared object file: No such file or directory
06-10 19:59:45 Loading MediaInfo library
06-10 19:59:45 Error loading MediaInfo library: Unable to load library 'mediainfo': libmediainfo.so: cannot open shared object file: No such file or directory
06-10 19:59:45 Make sure you have libmediainfo and libzen installed
06-10 19:59:45 The server will now use the less accurate FFmpeg parsing method
Any suggestions please.
Wayne
In New Zealand
geaves
Re: Missing MediaInfo
Post by geaves »
Have you tried downloading and installing from here http://mediainfo.sourceforge.net/en/Download this is what I used, you say these are installed...but so did my Linux distro, using this site solved the error.
torz77
Post by torz77 »
I just had this exact issue (one of many problems I'm trying to resolve) on Ubuntu 12.04 Server.
In my case the problem was that the symlinks to /usr/lib were set up incorrectly, so I just set up new ones without *.0 on the end:
mediainfo:
$ locate mediainfo
/usr/lib/libmediainfo.so.0
/usr/lib/libmediainfo.so.0.0.0
$ sudo ln -s /usr/lib/libmediainfo.so.0 /usr/lib/libmediainfo.so
libzen:
$ locate libzen
/usr/lib/libzen.so.0
/usr/lib/libzen.so.0.0.0
$ sudo ln -s /usr/lib/libzen.so.0 /usr/lib/libzen.so
HT1
Post by HT1 »
i'm getting this error message in logs about missing mediainfo file, have to fallback on ffmpeg
ums v5.2.0
Win 10 64bits
Qnap TS-212 2x3TB WD Red
Sony Bravia MN (my own conf)
FlyMcDoogal
Post by FlyMcDoogal »
Just noticed the same thing here !
Do you have MediaInfo installed? We don't bundle it for Linux
blipi
Post by blipi »
Try:
sudo apt-get install mediainfo libzen-dev libmediainfo-dev
I also had this problem and solved it by installing those 2 dev packages. Good luck ;)
alberteim
Post by alberteim »
Cheers Guys .. I'm running 64bit mint linux and have latest java installed.. for other stuff
I did the mediainfo and libzen stuff and that now I can see the renderer " Android"
on the setup page of UMS. it's registered..
I have had UMS 5.3 and 32bit mint running no probs on another machine and I thought
while I was on holidays to rebuild a pre loved pc and install UMS again on 64bit mint.
I'm running uPnPlay from from playstore on a Samsung Note 3 and it has worked
previously.
I'm running UMS 6.0.0 and it all seems to go but I can't see the ums server and directories
any clues.
Cheers alberteim
alberteim wrote:Cheers Guys .. I'm running 64bit mint linux and have latest java installed.. for other stuff
previously.
any clues.
Cheers alberteim
Turn off the firewall. If the issue still persists, create a new thread and post debug files as described on top of the page.
alberteim
Post by alberteim »
All solved re renderer, I had some java IO issues after trawling thru
the logs and they were solved by downloading a complete ffmpeg
and redoing the UMS config.
Thanks for your hints all is now working fine
Thanks alberteim
