Version 1.2.1 is released
General:
Changes since 1.2.0:
  • General:
    • Improved video buffer stability
    • The default versions of UMS.conf and WEB.conf are now put in ProgramData on Windows (thanks to vulcan for reporting this bug)
    • Updated UMS.conf
    • Updated renderer.conf creation instructions
    • Fixed AviSynth/FFmpeg crash
    • Improved AviSynth/FFmpeg engine code
    • Enabled convertfps by default
    • Made the AviSynth script instructions separate to the input box
    • Minor design improvements to the Transcoding tab
    • Made True Motion smoother
    • Assorted bugfixes
  • Languages:
    • Updated Catalan
    • Updated English
Upgrade Notes:
Glebb for compiling the OS X version.
The PMS developers.
Phonism
Re: Version 1.2.1 is released
Post by Phonism »
Thanks for another release :)
DeFlanko
Contact:
Post by DeFlanko »
Don't know if its due to the release but Mplayer.exe *32 uses 50% cpu before the load of UMS -- Checking fonts?
Should it be doing this?
Yeah it checks/creates the font cache for subtitles, no problem :)
Gareee
Post by Gareee »
I know this is a late bug report now that there is an update, but were seeing an odd behavior with this version. (I'll report if I still see it in today's update.)
Basically, my PC is left on for 24/7, and UMS is running the entire time.
My PS3 is turned on and off several times a day, and occasionally UMS would not show up as an available server. UMS still looks like its connected to the ps3 since it found it at startup. Sometimes having he ps3 search for servers again would pp it up, but most times I had to stop and restart UMS.
Not really a big deal, since it was an easy work around, but it might be something to keep an eye on for stability's sake.
Gareee
Post by Gareee »
Just replying again to turn on notifications in case of a reply.
