Unable to connect with Sony Bluray and Optoma projector
teidybugi
Post by teidybugi » Thu Dec 06, 2018 2:35 am
Hi!
I would like to connect to UMS with (at least one of) Sony Blu-ray player X800 and Optoma projector UHD51a. I'm a new guy to this and I can't connect with any of devices.
I would like to watch 4K HDR content like that, with lossless video quality, expect for audio since both devices can't play atmos or true-hd from single MKV file.
Any help would be much appreciated.
Sincerely,
teidybugi
squadjot
Re: Unable to connect with Sony Bluray and Optoma projector
Post by squadjot » Thu Dec 06, 2018 3:56 am
If you're on windows; sometimes it helps turning off the windows firewall.. let the program connect..and then turn firewall on again. (just have to do it once)
teidybugi
Post by teidybugi » Thu Dec 06, 2018 11:22 am
Thank you, that did the trick, but unfortunately I'm unable to connect if I turn firewall back. I would like to ask is there a way to play non transcoded files by default and how could I play MKV file but with AC3 audio? It can play with MPEG-2 but the quality is much worse than MKV and not sure why the skipping is much smoother with MKV.
Post by SubJunk » Thu Dec 06, 2018 3:55 pm
You can manually skip transcoding on the "Transcoding Settings" tab in UMS, down the bottom of that screen there is the "skip transcoding for the following extensions".
We would prefer ideally if you could provide us with logs and let us know which formats you are skipping so that we can update the config for that device, since if transcoding is happening when it doesn't need to be, that usually means there is something incorrect in the renderer configuration file
teidybugi
Post by teidybugi » Sun Dec 09, 2018 2:47 am
Sorry for late reply, I have some problems with UMS. At first I'm able to connect to the UMS, but I have to disable firewall everytime. I managed to play Darkest Hour 2160p HDR (I played it for couple of minutes), but HDR worked with MKV (no transcode) and for some reason it played audio, but unfortunately it didn't show subtitles even if there was external.
Then I wanted to try some other movies but folders wouldn't load anymore. I reset the UMS (with logging) and tried again, but it wouldn't load anything. So I'm posting 2 links for both logs. I don't think I have to transcode any video format, but for audio I'm sure I have to, so I would really like if it's possible to have MKV with transcoded audio.
ums_dbg_loading.zip
First log
(3.02 MiB) Downloaded 97 times
ums_dbg_first.zip
Second log - where it would be just loading screen
(3.71 MiB) Downloaded 93 times
squadjot
Post by squadjot » Sun Dec 09, 2018 1:07 pm
Hm, then you need to look up the firewall rule for Java SE Binaries (javaw.exe) and set it accordingly. (allow)
teidybugi
Post by teidybugi » Tue Dec 11, 2018 1:58 am
Okay, now I can connect to UMS without disabling firewall. For some movies when playing MKV on blu-ray I'm able to switch audio so it doesn't show unsupported audio anymore, but it still won't show subtitles, I'm assuming this is more of a problem for the blu-ray player than UMS.
I'm trying to connect with projector directly to UMS and it shows my PC (not sure why) and UMS, but when I press on UMS it just opens my PC where there are no files to play. And for some strange reason DLNA doesn't work with projector through Ethernet cable but with wi-fi does and I used the same cable I have for blu-ray player.
Post by SubJunk » Tue Dec 11, 2018 8:02 am
One of the main reasons UMS does transcoding is for subtitles support, so the idea is that we define which things (including which subtitles) a device supports in its renderer configuration file, and then everything that doesn't match that, is transcoded. I'd be happy to work with you to improve your renderer configs so that they will work without setting that "skip transcoding" thing, as that is just a blunt override. Would you be willing to test configs if I make them?
teidybugi
Post by teidybugi » Tue Dec 11, 2018 11:32 am
Yeah I would be glad to test configs. I was really bumped about it since I got new projector and I couldn't play movies as I wanted to, so I'm down for everything if we can make it work. And thank you for the assistance.
valib
Post by valib » Tue Dec 11, 2018 11:46 pm
@teidybugi please set shared folders acordingly. You have set
folders =I:\\,G:\\4k_3d_filmi
which means that all subfolders and files in I: drive will be scanned not only folders with any media files. It really spams the log and slow down browsing.
