Ubuntu 18.04 / UMS 7.7.1 -> Error when running from Archives
Patch
Post by Patch » Fri Jan 04, 2019 8:10 am
I have found that when I run files that are in in a separate container like .RAR or .TAR that I am unable to run.
I have seen several users reporting similar problems in recent builds with Subs.
I saw this other post: https://www.universalmediaserver.com/fo ... 10&t=13186 but they were running Mencoder as default.
I have personally tried to compile the latest build to see if it resolves the problem but haven't been able to resolve the dependencies... yet. If anyone has the latest build compiled, I will be willing to test them.
In the execution of my debug. I run the same source file twice. In this situation I took the file that was originally in a .RAR archive and extracted it.
Then I put it in a .TAR store ( not something I would normally due but I figured Ubuntu should have native support )
That fails.
I then run the file not in a compressed directly and it runs without problems.
11:49:54 DEBUG Starting transcode/remux of House.S08E01.720p.HDTV.X264-DIMENSION.mkv with media info: Container: MATROSKA, Size: 9223372034707292159, Video Bitrate: 0, Video Tracks: 1, Video Codec: h264, Duration: 0:43:09.790, Video Resolution: 1280 x 720, Frame Rate: 23.98, Audio Tracks: 1 [Audio Codec: AC3, Bitrate: 0, Channels: 2, Sample Frequency: 48000 Hz], DLNAThumbnail: [Format = JPEG, Resolution = 320×180, Size = 7570, DLNA Profile = JPEG_RES_320_180], Mime Type: video/x-matroska
11:49:54 DEBUG Starting mkfifo --mode=777 /tmp/UMS-ben/ffmpegvideo_98_1546544994360
11:49:54 DEBUG Unix process ID (mkfifo): 14513
11:49:54 DEBUG Starting /usr/ums/linux/ffmpeg64 -y -loglevel fatal -threads 16 -i pipe: -threads 16 -bufsize 500000k -maxrate 499000k -crf 19 -c:a copy -c:v libx264 -tune zerolatency -preset ultrafast -level 31 -pix_fmt yuv420p -f mpegts /tmp/UMS-ben/ffmpegvideo_98_1546544994360
11:49:54 DEBUG Reading pipe: /tmp/UMS-ben/ffmpegvideo_98_1546544994360
11:49:57 DEBUG External input stream instance is null... sounds not good, waiting 500ms
11:49:58 DEBUG External input stream instance is null... sounds not good, waiting 500ms
11:49:59 DEBUG External input stream instance is null... sounds not good, waiting 500ms
11:50:00 DEBUG External input stream instance is null... sounds not good, waiting 500ms
11:50:01 DEBUG External input stream instance is null... sounds not good, waiting 500ms
11:50:02 ERROR There is no inputstream to return for House.S08E01.720p.HDTV.X264-DIMENSION.mkv
11:50:02 ERROR External input stream instance is null... stopping process
11:50:02 DEBUG Stopping Unix process 14517: ffmpeg64-7
11:50:02 DEBUG Caught exception: null
11:50:02 DEBUG Stopping Unix process 14513: mkfifo-8
(193.3 KiB) Downloaded 71 times
Patch
Ubuntu 18.04 / UMS 7.7.1 -> Error when running from Compressed Archives
Post by Patch » Fri Jan 04, 2019 9:06 am
If I try to stream a MKV file that is archived in a .RAR or .TAR they fail.
This is a new install on Linux so I don't have a point of reference.
I stated with a video that was from a .RAR file it was unable to play, when I extract it, it works fine.
I also tried putting the file in a .TAR store just to compare and it also files.
I would prefer to run them from the archives. I have confirmed this is not related to the current subtitle bug as this source doesn't a track for that.
File instide a TAR
11:49:46 DEBUG Recognized media renderer "PlayStation 4"
11:49:46 DEBUG Starting transcode/remux of House.S08E01.720p.HDTV.X264-DIMENSION.mkv with media info: Container: MATROSKA, Size: 9223372034707292159, Video Bitrate: 0, Video Tracks: 1, Video Codec: h264, Duration: 0:43:09.790, Video Resolution: 1280 x 720, Frame Rate: 23.98, Audio Tracks: 1 [Audio Codec: AC3, Bitrate: 0, Channels: 2, Sample Frequency: 48000 Hz], DLNAThumbnail: [Format = JPEG, Resolution = 320×180, Size = 7570, DLNA Profile = JPEG_RES_320_180], Mime Type: video/x-matroska
11:49:46 DEBUG Starting mkfifo --mode=777 /tmp/UMS-ben/ffmpegvideo_141_1546544986332
11:49:46 DEBUG Unix process ID (mkfifo): 14494
11:49:46 DEBUG Stopping Unix process 14411: ffmpeg64-2
11:49:46 DEBUG Starting /usr/ums/linux/ffmpeg64 -y -loglevel fatal -threads 16 -i pipe: -threads 16 -bufsize 500000k -maxrate 499000k -crf 19 -c:a copy -c:v libx264 -tune zerolatency -preset ultrafast -level 31 -pix_fmt yuv420p -f mpegts /tmp/UMS-ben/ffmpegvideo_141_1546544986332
11:49:46 DEBUG Reading pipe: /tmp/UMS-ben/ffmpegvideo_141_1546544986332
11:49:48 DEBUG Sending ALIVE...
11:49:49 DEBUG External input stream instance is null... sounds not good, waiting 500ms
11:49:50 DEBUG External input stream instance is null... sounds not good, waiting 500ms
11:49:51 DEBUG External input stream instance is null... sounds not good, waiting 500ms
11:49:52 DEBUG External input stream instance is null... sounds not good, waiting 500ms
11:49:53 DEBUG External input stream instance is null... sounds not good, waiting 500ms
11:49:54 ERROR There is no inputstream to return for House.S08E01.720p.HDTV.X264-DIMENSION.mkv
11:49:54 ERROR External input stream instance is null... stopping process
11:49:54 DEBUG Caught exception: null
11:49:54 DEBUG Stopping Unix process 14499: ffmpeg64-5
11:49:54 DEBUG Stopping Unix process 14494: mkfifo-6
File working not in archive
11:50:10 DEBUG Starting /usr/ums/linux/ffmpeg64 -ss 4 -i "/mnt/md0/TV/House/Season 8/house.801.EXTRACTED/House.S08E01.720p.HDTV.X264-DIMENSION.mkv" -an -dn -sn -vf scale=320:-2 -vframes 1 -f image2 pipe:
11:50:10 DEBUG Unix process ID (/usr/ums/linux/ffmpeg64): 14543
11:50:10 DEBUG ffmpeg version N-80363-g403a53c-static http://johnvansickle.com/ffmpeg/  Copyright (c) 2000-2016 the FFmpeg developers
11:50:10 DEBUG   built with gcc 5.4.0 (Debian 5.4.0-4) 20160609
11:50:10 DEBUG   configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfribidi --disable-indev=sndio --disable-outdev=sndio --enable-librtmp --enable-libmfx --enable-libzimg --cc=gcc
11:50:10 DEBUG   libavutil      55. 24.100 / 55. 24.100
11:50:10 DEBUG   libavcodec     57. 46.100 / 57. 46.100
11:50:10 DEBUG   libavformat    57. 38.100 / 57. 38.100
11:50:10 DEBUG   libavdevice    57.  0.101 / 57.  0.101
11:50:10 DEBUG   libavfilter     6. 46.101 /  6. 46.101
11:50:10 DEBUG   libswscale      4.  1.100 /  4.  1.100
11:50:10 DEBUG   libswresample   2.  1.100 /  2.  1.100
11:50:10 DEBUG   libpostproc    54.  0.100 / 54.  0.100
11:50:10 DEBUG Input #0, matroska,webm, from '/mnt/md0/TV/House/Season 8/house.801.EXTRACTED/House.S08E01.720p.HDTV.X264-DIMENSION.mkv':
11:50:10 DEBUG   Metadata:
11:50:10 DEBUG     encoder         : libebml v0.7.7 + libmatroska v0.8.1
11:50:10 DEBUG     creation_time   : 2011-10-04 02:52:08
11:50:10 DEBUG   Duration: 00:43:09.79, start: 0.000000, bitrate: 3546 kb/s
11:50:10 DEBUG     Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
11:50:10 DEBUG     Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default)
11:50:10 DEBUG [swscaler @ 0x3e8cd60] deprecated pixel format used, make sure you did set range correctly
11:50:10 DEBUG [image2 @ 0x3f0d5c0] Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
11:50:10 DEBUG Output #0, image2, to 'pipe:':
11:50:10 DEBUG     encoder         : Lavf57.38.100
11:50:10 DEBUG     Stream #0:0(eng): Video: mjpeg, yuvj420p(pc), 320x180 [SAR 1:1 DAR 16:9], q=2-31, 200 kb/s, 23.98 fps, 23.98 tbn, 23.98 tbc
11:50:10 DEBUG       encoder         : Lavc57.46.100 mjpeg
11:50:10 DEBUG     Side data:
11:50:10 DEBUG       cpb: bitrate max/min/avg: 0/0/200000 buffer size: 0 vbv_delay: -1
11:50:10 DEBUG Stream mapping:
11:50:10 DEBUG   Stream #0:0 -> #0:0 (h264 (native) -> mjpeg (native))
11:50:10 DEBUG Press [q] to stop, [?] for help
11:50:10 DEBUG frame=    1 fps=0.0 q=3.2 Lsize=N/A time=00:00:00.04 bitrate=N/A speed=0.31x
11:50:10 DEBUG video:10kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
11:50:10 DEBUG Recognized media renderer "PlayStation 4"
11:50:11 DEBUG Recognized media renderer "PlayStation 4"
11:50:11 DEBUG Created playback timer for PlayStation 4
11:50:11 DEBUG Connection error: java.io.IOException: Broken pipe
11:50:11 DEBUG Premature end, stopping...
(193.3 KiB) Downloaded 76 times
Re: Ubuntu 18.04 / UMS 7.7.1 -> Error when running from Archives
Post by Nadahar » Fri Jan 04, 2019 11:30 am
I've looked at the code for compressed archives previously, and to sum it up: It seems to me like it was made for PS3 Media Server back when the program worked in a much simpler way. A lot has changed since then, but the archive code hasn't been updated accordingly. In addition there are many operations normally performed by UMS that simply isn't available from archives.
The result is that parsing fails, seeking fails and thumbnails fail. For it to work, you will need luck with the defaults so that no parsing is needed, and you can only play (video files) without seeking or pausing. I don't think audio and images are even implemented for archives.
Getting this to work properly is no small feat, it's not about "fixing a couple of bugs". Big parts of the logic is missing. The best thing to do would probably be to remove the option to play archives, since the implementation is so very lacking - but then I'm pretty sure those few whose needs are met by the current implementation would complain.
Regardless, unless you intent to undertake coding all that's missing, you're better of just assuming that UMS can't play archives.
Patch
Post by Patch » Fri Jan 04, 2019 7:15 pm
While I believe you are correct that the code likely hasn't been updated for a while, it does work on the Windows side.
This leads me to a believe its more than a code issue and either an OS subsystem or library.
I have been doing some research and it seems users running Kodi had similar problems. Maybe still have it.
I also found a few few utilities like rarfs and pyarrf that seem to have seem to have a handle on it but they use FUSE so that you can view the files through the UI.
Post by Nadahar » Sat Jan 05, 2019 1:22 am
Believe me, the limitations I describe ARE on Windows.
According to my memory, UMS only supports 3 different archives: ZIP, RAR and 7z. Both ZIP and RAR are pure Java implementations and should behave identical regardless of platform. 7-zip is not pure Java AFAICR, and wraps a C/C++ library to do the actual operations. Thus, it has the potential to behave differently on different platforms.
That said, TAR, ARJ, XZ, ACE and all the rest aren't supported.
Patch
Post by Patch » Sat Jan 05, 2019 6:58 am
Thanks, I will leave TAR from testing then. Just to be certain.
Been doing some analysis - learning way more about pipes then I ever though.
What I'm seeing is on the Linux side it attempts to create the pipe using mkfifo but I'm not sure if it is successful in doing so.
When FFmpeg tries to read back the pipe, there isn't anything there. I assume that UMS is doing more at this time than just what I see in the logs. I'm actually wondering if this is due to the version of FFMpeg being used.
No Archive- Windows
10:20:02 INFO  Started playing House.S08E01.720p.HDTV.X264-DIMENSION.mkv on your VLC for desktop
10:20:02 DEBUG The full filename of which is: F:\TV SHOWS\House\Season 8\house.801.EXTRACTED\House.S08E01.720p.HDTV.X264-DIMENSION.mkv and the address of the renderer is: 192.168.1.22
10:20:02 DEBUG Recognized media renderer "VLC for desktop"
10:20:02 DEBUG Connection error: java.io.IOException: An existing connection was forcibly closed by the remote host
10:20:02 DEBUG Premature end, stopping...
No Archive - Linux
10:22:29 INFO  Started playing House.S08E01.720p.HDTV.X264-DIMENSION.mkv on your VLC for desktop
10:22:29 DEBUG The full filename of which is: /mnt/md0/TV/House/Season 8/house.801.EXTRACTED/House.S08E01.720p.HDTV.X264-DIMENSION.mkv and the address of the renderer is: 192.168.1.22
10:22:29 DEBUG Recognized media renderer "VLC for desktop"
10:22:29 DEBUG Connection error: java.io.IOException: Connection reset by peer
RAR Archive - Windows
 [FFmpeg]'
10:21:06 DEBUG Reading maximum_video_buffer_size: 400 (previous: 770, default: 200)
10:21:06 DEBUG Starting transcode/remux of House.S08E01.720p.HDTV.X264-DIMENSION.mkv with media info: Container: MATROSKA, Size: 9223372034707292159, Video Bitrate: 0, Video Tracks: 1, Video Codec: h264 (High), Duration: 0:43:09.790, Video Resolution: 1280 x 720, Frame Rate: 23.98, Audio Tracks: 1 [Audio Codec: AC3, Bitrate: 0, Channels: 2, Sample Frequency: 48000 Hz], DLNAThumbnail: [Format = JPEG, Resolution = 320×180, Size = 7570, DLNA Profile = JPEG_RES_320_180], Mime Type: video/x-matroska
10:21:06 DEBUG Reading engines: "ffmpegvideo,ffmpegaudio,tsmuxeraudio,ffmpegwebvideo,vlcwebvideo,vlcvideo,mencoderwebvideo,vlcaudio,ffmpegdvrmsremux,dcraw" (previous: "ffmpegvideo,mencoder,ffmpegaudio,tsmuxeraudio,ffmpegwebvideo,vlcwebvideo,vlcvideo,mencoderwebvideo,vlcaudio,ffmpegdvrmsremux,dcraw", default: "ffmpegvideo,mencoder,tsmuxer,ffmpegaudio,tsmuxeraudio,ffmpegwebvideo,vlcwebvideo,vlcvideo,mencoderwebvideo,vlcaudio,ffmpegdvrmsremux,dcraw")
10:21:06 DEBUG Creating pipe \\.\pipe\ffmpegvideo_2386_1546626066430
10:21:06 DEBUG Waiting for Windows names pipe connection "\\.\pipe\ffmpegvideo_2386_1546626066430"
10:21:06 DEBUG Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg64.exe" -y -loglevel fatal -i pipe: -bufsize 31250k -maxrate 31250k -crf 19 -ab 320k -ar 48000 -c:a aac -c:v libx264 -tune zerolatency -preset ultrafast -level 31 -pix_fmt yuv420p -f mpegts \\.\pipe\ffmpegvideo_2386_1546626066430
10:21:06 DEBUG Reading pipe: \\.\pipe\ffmpegvideo_2386_1546626066430
10:21:06 DEBUG Attaching thread: ffmpeg64.exe-7
10:21:06 DEBUG Result of \\.\pipe\ffmpegvideo_2386_1546626066430: true
10:21:09 DEBUG Switching rendering context to 'null [FFmpeg]' from 'VLC for desktop [FFmpeg]'
10:21:09 INFO  Started playing House.S08E01.720p.HDTV.X264-DIMENSION.mkv on your VLC for desktop
10:21:09 DEBUG The full filename of which is: F:\TV SHOWS\House\Season 8\House.S08E01.720p.HDTV.X264-DIMENSION\house.801.720p-dimension.mkv and the address of the renderer is: 192.168.1.22
10:21:21 DEBUG Sending ALIVE...
10:21:21 DEBUG Recognized media renderer "VLC for desktop"
10:21:22 DEBUG Recognized media renderer "VLC for desktop"
10:21:28 DEBUG Connection error: java.io.IOException: An existing connection was forcibly closed by the remote host
RAR Archive - Linux
10:23:01 DEBUG Starting transcode/remux of House.S08E01.720p.HDTV.X264-DIMENSION.mkv with media info: Container: MATROSKA, Size: 9223372034707292159, Video Bitrate: 0, Video Tracks: 1, Video Codec: h264, Duration: 0:43:09.790, Video Resolution: 1280 x 720, Frame Rate: 23.98, Audio Tracks: 1 [Audio Codec: AC3, Bitrate: 0, Channels: 2, Sample Frequency: 48000 Hz], DLNAThumbnail: [Format = JPEG, Resolution = 320×180, Size = 7431, DLNA Profile = JPEG_RES_320_180], Mime Type: video/x-matroska
10:23:01 DEBUG Reading force_external_subtitles: false (previous: true, default: true)
10:23:01 DEBUG Starting mkfifo --mode=777 /tmp/UMS-ben/ffmpegvideo_525_1546626181473
10:23:01 DEBUG Unix process ID (mkfifo): 25953
10:23:01 DEBUG Starting /usr/bin/ffmpeg -y -loglevel fatal -threads 16 -i pipe: -threads 16 -bufsize 31250k -maxrate 31250k -crf 19 -ab 320k -c:a aac -c:v libx264 -tune zerolatency -preset ultrafast -level 31 -pix_fmt yuv420p -f mpegts /tmp/UMS-ben/ffmpegvideo_525_1546626181473
10:23:01 DEBUG Reading pipe: /tmp/UMS-ben/ffmpegvideo_525_1546626181473
10:23:04 DEBUG External input stream instance is null... sounds not good, waiting 500ms
10:23:05 DEBUG External input stream instance is null... sounds not good, waiting 500ms
10:23:06 DEBUG External input stream instance is null... sounds not good, waiting 500ms
10:23:07 DEBUG External input stream instance is null... sounds not good, waiting 500ms
10:23:08 DEBUG External input stream instance is null... sounds not good, waiting 500ms
10:23:09 ERROR There is no inputstream to return for House.S08E01.720p.HDTV.X264-DIMENSION.mkv
10:23:09 ERROR External input stream instance is null... stopping process
10:23:09 DEBUG Stopping Unix process 25957: ffmpeg-18
10:23:09 DEBUG Caught exception: null
10:23:09 DEBUG Stopping Unix process 25953: mkfifo-19
Patch
Post by Patch » Sat Jan 05, 2019 7:10 am
Nothing much here to go off of... but I did noticed something when looking at the commands for FFmpeg...
In particular, I will compare apples to apples and look at the two 6.8.0 builds.
Something I noticed is --enable-zlib on Windows. I would expect
Windows - UMS 6.8.0
-enable-bzlib --enable-zlib
ffmpeg version N-80363-g403a53c Copyright (c) 2000-2016 the FFmpeg developers
  built with gcc 5.4.0 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-nvenc --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib
Hyper fast Audio and Video encoder
Linux - Packaged with UMS 6.8.0
--enable-libzimg
Linux - Packaged with UMS 7.7.1
--enable-libzimg
Ubuntu - Latest Distro for 18.04
--enable-libzmq --enable-libzvbi
ffmpeg version 3.4.4-0ubuntu0.18.04.1 Copyright (c) 2000-2018 the FFmpeg developers
  built with gcc 7 (Ubuntu 7.3.0-16ubuntu3)
  configuration: --prefix=/usr --extra-version=0ubuntu0.18.04.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
  libavutil      55. 78.100 / 55. 78.100
  libavcodec     57.107.100 / 57.107.100
  libavformat    57. 83.100 / 57. 83.100
  libavdevice    57. 10.100 / 57. 10.100
  libavfilter     6.107.100 /  6.107.100
  libavresample   3.  7.  0 /  3.  7.  0
  libswscale      4.  8.100 /  4.  8.100
  libswresample   2.  9.100 /  2.  9.100
  libpostproc    54.  7.100 / 54.  7.100
What I have noticed is that the configuration is different. I am looking into now that the FFMpeg documentation now to find out if there is something that needs to be included when building it...
I also found TAR are supported on linux - https://ffmpeg.org/ffmpeg-protocols.html#subfile
Patch
Post by Patch » Sat Jan 05, 2019 7:21 am
Look what I found... Is this correct that this is still a known bug? It says its still open, but a change was commited.
valib commented on Jul 26, 2016 •
For compressed video files there is missing an external subs support for FFmpeg and also for MEncoder. I will check if it is possible to do that.
https://github.com/UniversalMediaServer ... issues/273
https://github.com/UniversalMediaServer ... 70a6435d30
Post by Nadahar » Sat Jan 05, 2019 8:09 am
I'm not sure if it matters at all what compression FFmpeg supports, I don't think it's done that way. If transcoding from archives is implemented (I don't remember), it's probably done via a pipe so that UMS first extracts the file and then feeds it to FFmpeg.
In any case, there's not much point in me going into more details on this unless I refresh my memory about this code, which isn't something I intend to do at this time.
Regarding your log snippets, you really should enable "trace" logging - you'll see much more about what's actually happening. The "debug" log is mostly useless for debugging ;)
