Disabling transcoding by default?
bodom
Post by bodom »
Hi there.
So, it looks like most of the videos sent to my TV are transcoded even when not needed: if i enter the #TRANSCODE# folder and try to play the video "as-is", it just works. Is there a way to disable transcoding by default and leave it available only in the #TRANSCODE# folder?
squadjot
Re: Disabling transcoding by default?
Post by squadjot »
The best thing would be if you could submit logs, so developers can adjust your device config to transcode only what's needed.
bodom
Post by bodom »
Thank you for the reply. I have no buttons, but i have the trace log anyway.
But it is several megabytes. What should i look for inside of it?
It seems I can't delete this message. Original content no longer relevant :shock:
These spambots might be broken. saw one linking to a non existent page on this forum instead of another site just the other day.
