Is there a easy way update UMS in Debian/ubuntu?
Re: Is there a easy way update UMS in Debian/ubuntu?
I guess it depends on how you define "easy". If you mean by using some package repository, I don't think that exists. That said, downloading and extract-overwrite the files should work just fine as long as UMS isn't working. That's certainly a lot "easier" than to rebuild for most people, but if you have all the development tools set up and configured, rebuilding might be considered just as "easy".
boss
Post by boss »
I keep all the versions of UMS I have downloaded on my server.
I have a startup script which starts UMS. Then I create a symbolic link from UMS to whichever version I want to use.
EG: satan /opt/ums # ln -s ums-9.1.0/ ums
