Version 9.1.0 released
Post by SubJunk » Fri Nov 01, 2019 7:31 pm
General:
This release expands the automatic updating feature to macOS and Linux, adds a dark mode icon for macOS, fixes support for subtitles on Samsung TVs and more!
Download:
You can download it from the front page, our other official mirrors, or install it via Docker with:
docker pull universalmediaserver/ums
Changes since 9.0.1
  • General:
    • Added automatic updating to Linux and macOS (it already existed on Windows)
    • Added the UMS version to the web interface
    • Added a different icon in macOS dark mode (thanks, bcbomb47!)
    • Fixed pixelation of icon on some Linux distributions
  • Renderers:
    • Fixed support for external subtitles on some Samsung TVs (thanks, pipin!)
    • Bulgarian (93%)
    • Croatian (29%)
    • Danish (99%)
    • Dutch (93%)
    • Finnish (100%)
    • Italian (100%)
    • Korean (33%)
    • Persian (35%)
    • Turkish (100%)
  • Dependencies:
    • Updated JRE to 1.8.231
Notes:
  • The Windows releases work on Windows Vista onwards.
pipin
Re: Version 9.1.0 released
Post by pipin » Sat Nov 02, 2019 4:13 am
Thanks for the release, but I got some errors during the installation.
"Error opening file for writing..." for some files related to Java like \jre-x64\bin\awt.dll
Regards,
Jens
POIZ
Post by POIZ » Sat Nov 02, 2019 7:46 am
Deleting a Podcast or something like that from the shared content side is not that easy. sometimes it simply reappears somtimes it doubles itself.
and the starting "splash screen" dont close it stays until i close it
boss
Post by boss » Sun Nov 03, 2019 6:18 pm
V9.1.0 continues to give me a problem which has been present since after V7.4.
It happens both on my LG-BP550 Bluray players and my LG WebOS TV.
The issue:
Fast forward once (2 x) and it's fine.
Fast forward again (4 x) and the video stalls for some time.
Sometimes I can press the play button to resume and sometimes I have to exit out of the movie.
erickps4
Post by erickps4 » Mon Nov 04, 2019 6:09 am
hi subjunk thanks for the release i'll check out. the 9.0.1 is working fine with ps4 pro media player i'll test this one aswell. :D
Post by SubJunk » Wed Nov 06, 2019 8:11 am
I would expect that to happen if you try to install when the previous one is still running. Can you try it again?
I've created issues on our GitHub tracker for those two things:
https://github.com/UniversalMediaServer ... ssues/1869
https://github.com/UniversalMediaServer ... ssues/1868
The issue:
I am spending a lot of time trying to compile new versions of MPlayer/MEncoder but after that I can look into this. It would help if you could identify exactly which version first had the problem (was it exactly 7.4?) and then post logs from the last version that worked, and the first version that has the problem. That will hopefully give me the information I need to identify the problem.
Thanks Erick!
boss
Post by boss » Wed Nov 06, 2019 2:06 pm
@SubJunk
V7.4 works fine with the fast forward. It was versions after V7.4 when it started.
I still have versions after that on my server so I will test each one and report which version the issue started.
Cheers
boss
Post by boss » Thu Nov 07, 2019 2:40 am
@SubJunk
The fast forward problem started with V7.5.0 and all versions after that . The version prior to that (V7.4.0) worked fine.
I have the TRACE logs for V7.4.0 and 7.5.0 whilst doing the fast forward.
Where can I post the log files to?
Post by SubJunk » Fri Nov 08, 2019 7:01 pm
That will be useful boss, there are instructions at viewtopic.php?f=3&t=556
boss
Post by boss » Fri Nov 08, 2019 11:36 pm
@SubJunk
Re: Fast forward issue.
Link to the zip file containing V7.4.0 and V7.5.0 logs:
https://gofile.io/?c=DzXwW1
