Version 10.3.0 released
General:
This release focuses on network stability and performance, by improving our automatic bandwidth management and enabling it by default, and improves support for renderers like Apple TV and the new foobar2000 app. We have also done many improvements to our video lookups API, including improving accuracy of TV series lookups, and speed.
Download:
Downloads for Windows, macOS and Linux, and commands for Docker and Homebrew are available on our download page or from our official mirrors.
Changes since 10.2.0:
  • General:
    • Improved automatic maximum bandwidth setting and enabled it by default
    • Improved performance of browsing folders
    • Fixed being able to click the web interface button before it is browsable
    • Fixed matching and prettifying some TV episodes
    • Fixed binding to virtual network interfaces by default (can still be forced)
  • Renderers:
    • Added support for foobar2000 mobile (thanks, jps92!)
    • Improved support for Apple TV 4K
    • Fixed audio support on Bravia EX 500
    • Arabic (96%) (thanks, خليل مراطلة !)
    • Chinese (Traditional) (thanks, Austin Zhang!)
    • Czech (100%)
    • Danish (100%) (thanks, NCAA!)
    • Finnish (100%) (thanks, Esko Gardner!)
    • Italian (96%) (thanks, Roberto crescia and tiwi90!)
    • Korean (99%) (thanks, VenusGirl!)
    • Polish (100%) (thanks, Karol Szastok!)
    • Portuguese (100%) (thanks, mariopinto!)
    • Russian (91%) (thanks, Artem4ik and Dmitry Lavrentev!)
    • Slovak (96%) (thanks, Lukáš Praznovec!)
    • Swedish (100%) (thanks, Erik Karlsson!)
    • Turkish (100%) (thanks, Burak Yavuz!)
  • Dependency updates:
    • Bump checkstyle from 8.40 to 8.41
    • Bump FFmpeg to latest
    • Bump thumbnailator from 0.4.13 to 0.4.14
    • Bump twelvemonkeys-imageio-version from 3.6.2 to 3.6.4
Operating system support:
  • Windows 7+, and limited support for Windows XP and Vista
  • macOS 10.10+
  • Docker
KONTROLMASTER
Contact:
Re: Version 10.3.0 released
Post by KONTROLMASTER »
It is very strange, but in this version I can't play .mkv files on my ps3, seems to be old-new problem! Happened before, but it was in early versions.
pipin
Post by pipin »
Thanks for the release.
Regards,
Jens
KONTROLMASTER wrote: Tue Mar 16, 2021 6:31 am It is very strange, but in this version I can't play .mkv files on my ps3, seems to be old-new problem! Happened before, but it was in early versions.
Can you try using the ffmpeg64.exe version from 10.2.0, in this? It may be a problem with that file
pipin wrote: Tue Mar 16, 2021 8:39 am Thanks for the release.
Thanks pipin :)
KONTROLMASTER
Contact:
SubJunk wrote: Tue Mar 16, 2021 4:22 pm
SubJunk wrote: Tue Mar 16, 2021 4:22 pmCan you try using the ffmpeg64.exe version from 10.2.0, in this? It may be a problem with that file
Much appreciated! Just rolled back to the previous version for now. It's working! Thanks! Don't know if it was my problem or the latest version.... Tried to change the "ffmpeg64.exe" but this won't work.
KONTROLMASTER
Contact:
Also I have just one more question about the subtitles. Why the FFMPEG engine is not quite properly performing the subtitles, for ex. I have a file with multiple sub's, and to play it I need to start playing it for the several (two or three times, a bit)? I like this engine, because it shows many of the file's subtitles right, despite of MEncoder, which sometimes displays it wrong (out of screen), even if the settings of the style isn't change.
elwexo
Post by elwexo »
I had to roll back to 10.2 too. I can't seem to attach logs (I'll start a new topic if that helps?) but found this with trace turned on:
TRACE 2021-03-17 20:05:06.452 [ffmpeg64.exe-15] EOF
INFO 2021-03-17 20:05:06.452 [ffmpeg64.exe-15] Process C:\Program Files (x86)\Universal Media Server\win32\ffmpeg64.exe has a return code of 1! Maybe an error occurred... check the log file
DEBUG 2021-03-17 20:05:06.984 [FFmpeg Thumbnail Failsafe] Stopping process: ffmpeg64.exe-8
TRACE 2021-03-17 20:05:07.355 [ffmpeg64.exe-15-Timer] buffered: 0 bytes / inputs: 0
DEBUG 2021-03-17 20:05:07.560 [FFmpeg Thumbnail Failsafe] Stopping process: ffmpeg64.exe-9
TRACE 2021-03-17 20:05:08.006 [HTTPv2 Request Worker 1] Finished sleeping for 2500 milliseconds
TRACE 2021-03-17 20:05:08.006 [HTTPv2 Request Worker 1] Did not send subtitle headers because configuration.isDisabledSubtitles() is true and dlna.getMediaSubtitle() is null
TRACE 2021-03-17 20:05:08.011 [StartPlaying Event] Matched media renderer "Sony Bravia 5500" based on address 10.1.1.55
TRACE 2021-03-17 20:05:08.011 [HTTPv2 Request Worker 1] Matched support line f:mpegps v:mpeg2|h264 a:aac-lc|ac3|mpa m:video/mpeg
TRACE 2021-03-17 20:05:08.012 [Windows Sleep Worker] Calling SetThreadExecutionState ES_SYSTEM_REQUIRED to prevent Windows from going to sleep
TRACE 2021-03-17 20:05:08.013 [HTTPv2 Request Worker 1] Ready to Stop: true
TRACE 2021-03-17 20:05:08.018 [HTTPv2 Request Worker 1] HEAD only response sent to Sony Bravia 5500:
elwexo wrote: Thu Mar 18, 2021 1:26 am I had to roll back to 10.2 too. I can't seem to attach logs (I'll start a new topic if that helps?) but found this with trace turned on:
Your post got picked up as possible spam and needed to be approved, you should be able to attach your logs now.
I think there may be a problem with the version of ffmpeg in this update, I've read another issue about it that is fixed by using an older version.
elwexo
Post by elwexo »
No problem. Perhaps it's the channel that's stopping me from attaching logs - I still can't in this thread. Anyhow, I've made a new post in the support channel with my debug logs attached in case it's useful - it really only identifies that ffmpeg failed.
That's fixed in 10.4.0 which is released now. Sorry for the trouble caused by that. We are looking into why FFmpeg has that problem for some people and not others
