Displaying cbr comics
I've got a bunch of comics in *.cbr files.
Can these be displayed on the TV with UMS.
How would I do it?
How does one navigate?
Thank.
How would I do it?
Thank.
- SharkHunter
- Developer
Re: Displaying cbr comics
CBR files are supported by UMS. UMS will open the archive and display all the files within the archive as individual files. Navigating is up to your render.
You just have to make sure that the config option "Browse compressed archives" is set.
In $HOME/.config/UMS/UMS.conf
enable_archive_browsing = true
In $HOME/.config/UMS/debug.log
DEBUG 2014-05-05 19:17:16.262 [Library Scanner] Scanning Folder: Comics
TRACE 2014-05-05 19:17:16.265 [Library Scanner] Could not match any format to "/data/Pictures/Comics/105.cbr"
TRACE 2014-05-05 19:17:16.265 [Library Scanner] Could not match any format to "/data/Pictures/Comics/106.cbr"
TRACE 2014-05-05 19:17:16.266 [Library Scanner] Could not match any format to "/data/Pictures/Comics/106.cbr"
> cd /data/Pictures/Comics/
> file 105.cbr
105.cbr: RAR archive data, v14, os: Win32
Help
Thanks.
RME
> file 105.cbr
Help
Thanks.
RME
- SharkHunter
- Developer
Archives can't be scanned.
But you can browse them.
And you must restart to make the enable_archive_browsing flag to take effect.
If you still have problems upload full logs. I tried with a cbr archive and it works for me.
After re-start, I can see the comic pages but when I select one, I get an
Exception.
See Attachment (debug.log and UMS.conf).
RME
Exception.
RME
- debug_conf.zip
- (25.58 KiB) Downloaded 489 times
- SharkHunter
- Developer
That looks weird. It tries to find subtitles. That NPE should be plugged anyway. Try switching off v2 (I don't know what it is called actually but on the network tab there should be something called v2).
Thanks.
Set it to use the non-v2 version but still no luck. Still got an Exception.
I might add that the tv is a Samsung UN60F7100 so that might be the issue,
no one else is using one with UMS (?).
Attached is the log file.
This is really not a high priority with me; I just wanted to check out UMS's
features.
RME
features.
RME
- debug_conf2.zip
- (23.99 KiB) Downloaded 454 times
