UMS XB1 and New Virgin media Super Hub...HELP!!!!
Hi all, I'm running out of ideas, so below is the post I put to my ISP and afterwards some more UMS info:
Just had a new Superhub installed and since installation I am having the following problems:
1. Port is now Strict on all my Xbox's
Have kind of solved this by making a static IP and DMZ for 1 Xbox which now says Port Open....BUT...It also states that my Network is behind a Port Symetric NAT.
2. Since installation my DLNA Media Server (Universal Media Server) is not picked up on ANY of 2 Xbox ones 1 Xbox and 2 DLNA receiving TV's
I have tried reinstalling ALL software etc. and still no DLNA devices present.
Obviously the New router is the source of the problem but I can't figure out how to solve it.
So, In summary, UMS was working fine with the beta version that solved the problem of the XBox not seeing the UMS, but since the New router I have the same old Problem again >.<
Have tried reinstalling etc and no joy, UMS doesn't show up on any of my xbox's or my DLNA TV...
Any ideas??
Cheers
Drac
Any ideas??
Cheers
Drac
