Excpetion with PMSEncoder
I added the latest PMSEcoder plugin to the plugins folder and I am getting this error:
Full debug log attached
INFO 2014-12-07 16:34:39.746 [main] PMSEncoder: loading built-in log4j config file: jar:file:/C:/Program%20Files%20(x86)/Universal%20Media%20Server/plugins/pmsencoder-2.0.0.jar!/log4j_default.xml
INFO 2014-12-07 16:34:39.938 [main] Exception in thread "main" java.lang.NoClassDefFoundError: java/util/HashMap$Entry
INFO 2014-12-07 16:34:39.940 [main] at java.lang.Class.getDeclaredMethods0(Native Method)
INFO 2014-12-07 16:34:39.941 [main] at java.lang.Class.privateGetDeclaredMethods(Unknown Source)
INFO 2014-12-07 16:34:39.941 [main] at java.lang.Class.getDeclaredMethods(Unknown Source)
INFO 2014-12-07 16:34:39.942 [main] at org.codehaus.groovy.reflection.CachedClass$3$1.run(CachedClass.java:84)
INFO 2014-12-07 16:34:39.942 [main] at java.security.AccessController.doPrivileged(Native Method)
INFO 2014-12-07 16:34:39.943 [main] at org.codehaus.groovy.reflection.CachedClass$3.initValue(CachedClass.java:81)
INFO 2014-12-07 16:34:39.943 [main] at org.codehaus.groovy.reflection.CachedClass$3.initValue(CachedClass.java:79)
INFO 2014-12-07 16:34:39.943 [main] at org.codehaus.groovy.util.LazyReference.getLocked(LazyReference.java:46)
INFO 2014-12-07 16:34:39.943 [main] at org.codehaus.groovy.util.LazyReference.get(LazyReference.java:33)
INFO 2014-12-07 16:34:39.944 [main] at org.codehaus.groovy.reflection.CachedClass.getMethods(CachedClass.java:250)
INFO 2014-12-07 16:34:39.944 [main] at groovy.lang.MetaClassImpl.populateMethods(MetaClassImpl.java:343)
INFO 2014-12-07 16:34:39.945 [main] at groovy.lang.MetaClassImpl.fillMethodIndex(MetaClassImpl.java:293)
INFO 2014-12-07 16:34:39.945 [main] at groovy.lang.MetaClassImpl.initialize(MetaClassImpl.java:3048)
INFO 2014-12-07 16:34:39.945 [main] at org.codehaus.groovy.reflection.ClassInfo.getMetaClassUnderLock(ClassInfo.java:176)
INFO 2014-12-07 16:34:39.946 [main] at org.codehaus.groovy.reflection.ClassInfo.getMetaClass(ClassInfo.java:192)
INFO 2014-12-07 16:34:39.946 [main] at com.chocolatey.pmsencoder.Stash.$getStaticMetaClass(Stash.groovy)
INFO 2014-12-07 16:34:39.946 [main] at com.chocolatey.pmsencoder.Stash.<init>(Stash.groovy:15)
INFO 2014-12-07 16:34:39.947 [main] at com.chocolatey.pmsencoder.Matcher.<init>(Matcher.groovy:44)
INFO 2014-12-07 16:34:39.947 [main] at com.chocolatey.pmsencoder.Plugin.createMatcher(Plugin.groovy:254)
INFO 2014-12-07 16:34:39.948 [main] at com.chocolatey.pmsencoder.Plugin.<init>(Plugin.groovy:182)
INFO 2014-12-07 16:34:39.948 [main] at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
INFO 2014-12-07 16:34:39.948 [main] at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
INFO 2014-12-07 16:34:39.949 [main] at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
INFO 2014-12-07 16:34:39.949 [main] at java.lang.reflect.Constructor.newInstance(Unknown Source)
INFO 2014-12-07 16:34:39.949 [main] at java.lang.Class.newInstance(Unknown Source)
INFO 2014-12-07 16:34:39.950 [main] at net.pms.external.ExternalFactory.instantiateEarlyListeners(ExternalFactory.java:417)
INFO 2014-12-07 16:34:39.950 [main] at net.pms.external.ExternalFactory.lookup(ExternalFactory.java:397)
INFO 2014-12-07 16:34:39.950 [main] at net.pms.PMS.init(PMS.java:638)
INFO 2014-12-07 16:34:39.951 [main] at net.pms.PMS.createInstance(PMS.java:1035)
INFO 2014-12-07 16:34:39.951 [main] at net.pms.PMS.main(PMS.java:1135)
INFO 2014-12-07 16:34:39.952 [main] Caused by: java.lang.ClassNotFoundException: java.util.HashMap$Entry
INFO 2014-12-07 16:34:39.952 [main] at java.net.URLClassLoader$1.run(Unknown Source)
INFO 2014-12-07 16:34:39.953 [main] at java.security.AccessController.doPrivileged(Native Method)
INFO 2014-12-07 16:34:39.953 [main] at java.net.URLClassLoader.findClass(Unknown Source)
INFO 2014-12-07 16:34:39.953 [main] at java.lang.ClassLoader.loadClass(Unknown Source)
INFO 2014-12-07 16:34:39.954 [main] at java.lang.ClassLoader.loadClass(Unknown Source)
- (14.79 KiB) Downloaded 616 times
- SharkHunter
- Developer
Re: Excpetion with PMSEncoder
Most likely you have some permission error that don't let you write the log file. Change permissions.
It has nothing to do with permissions.SharkHunter wrote:Most likely you have some permission error that don't let you write the log file. Change permissions.
I'm running as Administrator and the file pmsencoder.log is created in C:\ProgramData\UMS
I've deleted it and it has been created again when I run UMS.
Same plugin with same permission runs perfect in PS3 Media Server.
- SharkHunter
- Developer
The fault is described here http://groovy.329449.n5.nabble.com/NoCl ... 20093.html and in short it's the new java has done some change to HashMap which groovy can't cope with. So your options are to either use java7 or try and fix PMSEncoder to work under java8.
PMSEncoder is incompatible with current UMS even if you get past this bug, the codebase has diverged and it would need patching.
I've removed Java 8 and installed Java 7.SharkHunter wrote:The fault is described here http://groovy.329449.n5.nabble.com/NoCl ... 20093.html and in short it's the new java has done some change to HashMap which groovy can't cope with. So your options are to either use java7 or try and fix PMSEncoder to work under java8.
Now I get a different exception with PMSEncoder.
- SharkHunter
- Developer
Read infidels last post again. UMS has diverged a bit from PMS and PMSEncoder will most likely not work with UMS.gabriels wrote:I've removed Java 8 and installed Java 7.SharkHunter wrote:The fault is described here http://groovy.329449.n5.nabble.com/NoCl ... 20093.html and in short it's the new java has done some change to HashMap which groovy can't cope with. So your options are to either use java7 or try and fix PMSEncoder to work under java8.
Maybe you should remove it from your plugins link in the help tab?SharkHunter wrote:Read infidels last post again. UMS has diverged a bit from PMS and PMSEncoder will most likely not work with UMS.gabriels wrote:I've removed Java 8 and installed Java 7.SharkHunter wrote:The fault is described here http://groovy.329449.n5.nabble.com/NoCl ... 20093.html and in short it's the new java has done some change to HashMap which groovy can't cope with. So your options are to either use java7 or try and fix PMSEncoder to work under java8.
Me I am back to PMS since I only need it for PMSEncoder.
- SharkHunter
- Developer
Exactly which function of PMSencoder is it you use. We/I have move most of the functionallity into UMS and other plugins.
I am streaming from SopCast to my PS3 using PMSEncoder.SharkHunter wrote:Exactly which function of PMSencoder is it you use. We/I have move most of the functionallity into UMS and other plugins.
If you have a solution for this I'd be happy.
