DLNA 2104 error please help
Hello everyone is a pleasure to be part of this forum,sorry if the topic had already been discussed ...
I tried different solutions, from the firewall (give permission) add universal media server services windows (OS xp professional) turn off and turn on the router (netgear WNR3500L) but nothing more and error protocol dlna 2104 insists does not load all the files video from hard disk of the pC...Please help me
Re: DLNA 2104 error please help
Advice please?be good
Devs will need more info to be able to help you. Where do you get that error? What's your renderer? Could you please post logs as per viewtopic.php?f=3&t=556 ?
Hello and thanks
you are right about most need information
I'll check as soon as possible and then send file
the console PlayStation 3 error is protocol dlna 2104
Universal media server sees all hard drives from PC but does not load all the files from folders
and error continues to appear and disappear
see you later
thanks
see you later
thanks
Okay? I hope I have done everything correctly
Hi
Excuse me, you have suggestions to solve this problem?
Sorry you didn't follow instruction at viewtopic.php?f=3&t=556 and you didn't set the loging level to TRACE. So there are not any usefull information in the log. Please try it again.
EDIT: and please install the latest UMS version
It did as you said if it's wrong, tell me where
thanks
There is nothing wrong in the log. Maybe this http://community.us.playstation.com/t5/ ... p/27588555 can help you.
Thanks valib;)
Yesterday was hell
I practically disconnected continuously
the router passed from 1000 to 100 mb(light green to light orange)
the firewall was turned off and everything seems ok but hard...
I'll watch the official forum topic and hope to solve
Yesterday was hell
