Live Streaming.
Live Streaming.
Is anyone able to tell me how to get live streaming to work?
Specifically, twitch.tv. I've tried the following in WEB.conf:
videostream.Web,Twitch=Honcast,http://www.twitch.tv/honcast
videostream.Web,Twitch=Honcast,http://www.twitch.tv/widgets/live_embed ... el=honcast
videostream.Web,Twitch=Honcast,mms://http://www.twitch.tv/honcast
videostream.Web,Twitch=Honcast,mms://http://www.twitch.tv/widgets/live_embed ... el=honcast
videostream.Web,Twitch=Honcast,mmst://http://www.twitch.tv/widgets/live_embed ... el=honcast
videostream.Web,Twitch=Honcast,rtmp://http://www.twitch.tv/honcast
videostream.Web,Twitch=Honcast,rtmp://http://www.twitch.tv/widgets/live_embed ... el=honcast
videostream.Web,Twitch=Honcast,rtmpe://http://www.twitch.tv/widgets/live_embed ... el=honcast
None of them work i just get the "This content cannot be played (800288E1)" error.
- (12.2 KiB) Downloaded 500 times
Re: Live Streaming.
anyone?
- SharkHunter
- Developer
Re: Live Streaming.
Your log contains only startup code. Reproduce the bug with logging enabled and set to TRACE see viewtopic.php?f=9&t=556
On a side not Livestreaming urls needs more resolving. Look at the Channels/Jumpy/PMSEncoder plugins.
Re: Live Streaming.
I know this. The reason I didn't bother reproducing the "bug" is because I'm pretty sure it's not a bug and the reason I uploaded it at all is so you could see my configs. Regardless, new attachment.SharkHunter wrote:Your log contains only startup code. Reproduce the bug with logging enabled and set to TRACE see viewtopic.php?f=9&t=556
What do you mean by resolving? A more accurate url? I've tried looking for a RTMP url with URLSnooper and that couldn't fine one. I'm sure you can view twitch streams outside of their site because with the use of this app you can watch streams in vlc/mplayer (although I have no idea how it's done) Also, need more information on those plugins. I've tried using Jumpy and PMSEncoder before and they didn't help.SharkHunter wrote:On a side not Livestreaming urls needs more resolving. Look at the Channels/Jumpy/PMSEncoder plugins.
- (25.13 KiB) Downloaded 492 times
- SharkHunter
- Developer
Re: Live Streaming.
Yes it is ofcourse possible to snoop out the rtmp url, thats what Channels/Jumpy/PMSEncoder does. But you'll need to update those plugins when you add new soruces. Or you need to dig out the complete url before adding it to the WEB.conf.
From what is seen in the logs and this:
the urls you've added are not the complete urls that can be used for streaming. Adding stuff like this "rtmp://http://" will never work as it is a maformed url that will produce some errors at best.
So if you want to look at twitch over UMS you'll need to either dig deeper so yo get the real url. Or get some plugin to automatically resolve the url. Since there is a app that can do this it could most likely be integrated into Channels/jumpy.
mms://http://www.twitch.tv/widgets/live_embed_player.swf?channel=honcast
Re: Live Streaming.
Alright, so I've installed Channels via the plugin manager (seems to have installed PMSEncoder too). Also have removed all the links from the WEB.conf. What do I do now? You said that PMSEncoder/Channels/Jumpy can snoop the rtmp link, so I'm assuming all that needs to be inputted is the regular http web url (http://www.twitch.tv/honcast) somewhere (dunno where to actually put said link)? Do I need to install Jumpy as well?
EDIT: Tried sniffing the rtmp link with URLSnooper, Wireshark, RTMPExploreX and Stream Transport. None of them found any rtmp links. I have no idea how livestreamer is getting the right link. I tried looking in the twitch plugin for it but I don't know python.
- SharkHunter
- Developer
Re: Live Streaming.
No I didn't say that those plugin can snoop the rtmp url. I said they could be updated to do that. That is a process that requires some sort of programming normally. Either you do that yourself, Channels uses it's own "language" (which can use any sort of script language) for creating Channels, jumpy relies on Python and PMSEncoder on groovy.
Here is a sample from Channels. This is YouTube
https://github.com/SharkHunter/Channel/ ... youtube.ch
It relies on another script for producing the real YouTube url
https://github.com/rg3/youtube-dl/raw/2 ... youtube-dl
Re: Live Streaming.
Well, by the looks of your post the first sentence said that they did then the last sentence said what you said in this post. I'm confused. Anyway, I can't find any rtmp link for twitch no matter what url sniffer I use. All I want to do is play twitch streams on my tv through UMS.SharkHunter wrote:No I didn't say that those plugin can snoop the rtmp url. I said they could be updated to do that. That is a process that requires some sort of programming normally. Either you do that yourself, Channels uses it's own "language" (which can use any sort of script language) for creating Channels, jumpy relies on Python and PMSEncoder on groovy.
- SharkHunter
- Developer
Re: Live Streaming.
I said that is what those plugin does, fetches rtmp urls. But they don't do that for a random site on the internet. If your site is supported by one of those plugins all is well.
We are about to add a new interface to UMS called URLResolver which would do just this BUT you still need to add some special code for each new site on the intenet you which to stream.
Looking at twitch it looks fairly simple to fix that site since they got an API. That said someone still has to do it.
Re: Live Streaming.
I'll wait until that gets implemented then. Currently it looks like there's no way to play twitch livestreams.
