MovieInfo
Discuss third party additions, plugins and translations for Universal Media Server
AramiS
MovieInfo
Post by AramiS » Sat Jun 02, 2012 9:32 pm
PLS :D
SharkHunter
Re: IMDB Plugin PLS!!!
Post by SharkHunter » Sun Jun 03, 2012 7:07 am
The MovieInfo plugin (which integrates with IMDB) works with UMS. So why not try that one? Look at my github or my googlecode.
S7eele
Post by S7eele » Thu Jun 07, 2012 3:02 pm
Is that the case with major plugins?
Peace!
Post by SubJunk » Thu Jun 07, 2012 3:14 pm
Yes, as far as I know all plugins that work with PMS work with UMS
S7eele
Post by S7eele » Thu Jun 07, 2012 3:20 pm
Sorry! Maybe look at the plugins page :oops:
Peace!
Post by SubJunk » Thu Jun 07, 2012 3:59 pm
:D
AramiS
Post by AramiS » Thu Jun 07, 2012 6:45 pm
This is the newest version? http://www.ps3mediaserver.org/forum/vie ... 520#p63942
Greetings!
SharkHunter
Post by SharkHunter » Thu Jun 07, 2012 7:48 pm
I think this (http://code.google.com/p/sharkhunter-sh ... ieinfo.jar) should be sort of the latest. Download that one + the conf file (http://sharkhunter-shb.googlecode.com/s ... EINFO.conf) and off you go. If you're not scared of code then clone my MovieInfo repo from https://github.com/SharkHunter/MovieInfo and compile it yourself. The jar file found at github hasn't been updated for a while but it works (mybe without ExSports latest changes which I think I added on google-code).
As a side note in the forthcomming 1.1 release of UMS the poor man imdb support is enabled in UMS. This means that if you in your filename (or in the name of a directory) adds _imdb<id>_ then the MovieInfo plugin will pick the imdbid straight from there and the integration is faster and better. UMS will also remove the _imdb<id>_ string from the filename so it will still look nice....
sjpirri
Post by sjpirri » Mon Jun 25, 2012 4:27 pm
SharkHunter how do you compile the Movie Info plugin i tried it using jar cf imbd.jar ~/imbd/net and ums doesn't pick up the jar so i guess i compiled it wrong :oops:
SharkHunter
Post by SharkHunter » Mon Jul 02, 2012 5:11 am
sjpirri wrote:SharkHunter how do you compile the Movie Info plugin i tried it using jar cf imbd.jar ~/imbd/net and ums doesn't pick up the jar so i guess i compiled it wrong :oops:
I compile from within eclipse. (or rather export -> jar bla blah).
It probably doesn't work for you beacuse you miss the "plugin" file (https://github.com/SharkHunter/MovieInf ... ter/plugin) that must be found in the roo of the jar file...
