MovieInfo
Re: IMDB Plugin PLS!!!
For me, the first lookup works (I get the description and stuff from IMDB, very cool), but then subsequent attempts don't find anything.
I'm getting errors like this in Traces, so I guess it means the URLs need to be validated to avoid that error:
INFO  2012-10-08 18:30:31.398 [pool-59-thread-1] java.net.MalformedURLException: no protocol: /images/widgets/facebook_share.png
INFO  2012-10-08 18:30:31.398 [pool-59-thread-1] 	at java.net.URL.<init>(Unknown Source)
INFO  2012-10-08 18:30:31.400 [pool-59-thread-1] 	at java.net.URL.<init>(Unknown Source)
INFO  2012-10-08 18:30:31.400 [pool-59-thread-1] 	at net.pms.movieinfo.FileMovieInfoVirtualFolder.displayTitle(FileMovieInfoVirtualFolder.java:249)
INFO  2012-10-08 18:30:31.400 [pool-59-thread-1] 	at net.pms.movieinfo.FileMovieInfoVirtualFolder.resolve(FileMovieInfoVirtualFolder.java:178)
INFO  2012-10-08 18:30:31.400 [pool-59-thread-1] 	at net.pms.dlna.DLNAResource.run(DLNAResource.java:790)
INFO  2012-10-08 18:30:31.401 [pool-59-thread-1] 	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO  2012-10-08 18:30:31.401 [pool-59-thread-1] 	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO  2012-10-08 18:30:31.401 [pool-59-thread-1] 	at java.lang.Thread.run(Unknown Source)
Followed by this which causes UMS to freeze:
INFO  2012-10-08 18:31:37.816 [pool-59-thread-1] Exception in thread "pool-59-thread-1" java.lang.OutOfMemoryError: Java heap space
INFO  2012-10-08 18:31:37.817 [pool-59-thread-1] 	at java.util.Arrays.copyOfRange(Unknown Source)
INFO  2012-10-08 18:31:37.817 [pool-59-thread-1] 	at java.lang.String.<init>(Unknown Source)
INFO  2012-10-08 18:31:37.817 [pool-59-thread-1] 	at java.lang.AbstractStringBuilder.substring(Unknown Source)
INFO  2012-10-08 18:31:37.817 [pool-59-thread-1] 	at java.lang.StringBuffer.substring(Unknown Source)
INFO  2012-10-08 18:31:37.817 [pool-59-thread-1] 	at net.pms.movieinfo.plugins.IMDBPlugin.getCast(IMDBPlugin.java:154)
INFO  2012-10-08 18:31:37.818 [pool-59-thread-1] 	at net.pms.movieinfo.FileMovieInfoVirtualFolder.resolve(FileMovieInfoVirtualFolder.java:197)
INFO  2012-10-08 18:31:37.818 [pool-59-thread-1] 	at net.pms.dlna.DLNAResource.run(DLNAResource.java:790)
INFO  2012-10-08 18:31:37.818 [pool-59-thread-1] 	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO  2012-10-08 18:31:37.818 [pool-59-thread-1] 	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO  2012-10-08 18:31:37.818 [pool-59-thread-1] 	at java.lang.Thread.run(Unknown Source)
ExSport
Re: MovieInfo
Post by ExSport »
Try this one which works with official PMS (latest SB build)
Edit config file as required (check ChangeLog http://www.ps3mediaserver.org/forum/vie ... 520#p63942)
It works for me without problems (I am sure with CSFD plugin, IMDB tested when new version released and it worked (end of Janurary 2012) 8-) )
MovieInfo_latest.zip
MovieInfo by ExSport (latest)
(88.79 KiB) Downloaded 1161 times
SharkHunter
Re: MovieInfo
Post by SharkHunter »
ExSport - I think SubJunk is on the move of fixing the issues ;) If you got something make a pull req on github and we can keep MovieInfo up to speed. I aint the most frequent user of MovieInfo myself but so I might miss some updates of it. (I got to many projects cooking....)
ExSport
Re: MovieInfo
Post by ExSport »
What I remember when I did last patches I published it to your github to be "official"
So I suppose your trunk should be latest (from 17 JAN 2012?)
This one works for me but can't test it with UMS and with enabled IMDB right now (CSFD.CZ definitely works :mrgreen: )
SharkHunter
Re: MovieInfo
Yes my github is up to date with your fixes from january. BTW Welcome here ExSport...;)
Re: MovieInfo
Welcome ExSport! Hope to see you here more ;)
Well from my testing, both versions (ExSport's and SharkHunters) have the bug, but it happens at different times randomly. Sometimes it happens on the first movie lookup, other times I can look up 4 before it happens.
Usually when it freezes it leaves no info in the debug.log, the program just stops working and must be forced closed (the Quit button works but doesn't close javaw.exe)
My suspicion is that there is a memory leak somewhere, like maybe the processes that look up the web info aren't being terminated properly, or maybe too many are running at the same time. I'll look into it.
ExSport
Re: MovieInfo
Post by ExSport »
Hi guys 8-)
Glad to see you again...found little time so I had time to register.
About MovieInfo, try to disable IMDB engine and use CSFD only. If it will work, problem is parser for IMDB...maybe site changed again so IMDB code started to make exceptions :roll:
Hopefully will have time this weekend to test UMS...stucked on last SB build 8-)
tmk
Re: MovieInfo
Post by tmk »
@ExSport: Any update to the IMDB code forthcoming? As noted, seems something has changed on the IMDB side to "break" genre and rating.
Server Platform: Linux Xubuntu 14.04 (LTS)
Renderer: Sony Bravia KDL-40W5100
SharkHunter
Re: MovieInfo
There are long times between updates but now there is one. Fetch it here http://code.google.com/p/sharkhunter-shb/downloads/list
One a UMS with rtmp support is available you'll be able to see trailers from IMDB. I also fixed the cast pics which where horrible....
tmk
Re: MovieInfo
Post by tmk »
SharkHunter wrote:There are long times between updates but now there is one. Fetch it here http://code.google.com/p/sharkhunter-shb/downloads/list....
Cheers!
