Nothing plays with Sony KD65-XD7505
My Sony KD65-XD7505 (Android TV) plays nothing.
It displays the video list but when starting a video i get an animated ring forever...
Here is the debug bundle.
- (49.92 KiB) Downloaded 486 times
Re: Nothing plays with Sony KD65-XD7505
Bump, new debug logs for new UMS version
- (81.86 KiB) Downloaded 522 times
Your TV is not properly recognized. Try the attached conf.
EDIT: I see that Sami32 was faster here viewtopic.php?f=3&t=9105
- Sony-BraviaXD.conf
- (2.13 KiB) Downloaded 525 times
Thanks,
I had it work once on a video then i tried fast forwarding... Now nothing plays even if i reboot UMS and the TV...
Here are the logs
Here are the logs
- (68.37 KiB) Downloaded 502 times
Hi Algrenadine,
https://raw.githubusercontent.com/Unive ... viaXD.conf
(Don't be surprise if the default icon appear, it will be fine in the next UMS version, or you can edit the file and replace by Sony-BraviaX.png)
Or try this one: But as told in this "remaked" configuration file you'll need to add
into your UMS.conf file placed in your UMS profile folder (not into the UMS.conf found in your Universal "Media Server" program folder).
Hoping that help.
If not, don't hesitate to post a new TRACE log while using this new setting.
chromecast_extension=false
Hoping that help.
Sami32 wrote:Hi Algrenadine,
Or try this one: But as told in this "remaked" configuration file you'll need to addinto your UMS.conf file placed in your UMS profile folder (not into the UMS.conf found in your Universal "Media Server" program folder).Code: Select all
Hoping that help.
Hi Sami32,
Thanks a lot for your help, it's getting better
Now playing and Fast Forwarding works. But hitting stop then trying to restart at the position i was with the "Resume : xxxx" entry in the folder doesn't work and cycles in a wait ring forever...
Attached tracelogs
I'm glad to learn that's solved all your connection errors
You used the first configuration file that i posted to you, right ?
About this other issue, related to "resume" function, i never looked at it, but i now that it affect some users around. Maybe some DLNA non standard handling
Yes i used the second one from your post.
It didn't solved my problems though as the resume option is not working....
Sorry i modified my post just before reading your answer.
Did the 2 configuration files worked, or only the last one ?
I need to know, for the next UMS version implementation.
Your second "resume" issue is totally different and would require more investigation in UMS code.
I only tried the second one, it worked.
Let met try the first one
