Version 2.6.5 is released
General:
This fixes compatibility with the latest Java update, updates translations and networking stability.
Changes since 2.6.4:
  • General:
    • Made sure it is possible to override thumbnails
    • Fixed RAW image transcoding and support 28 additional RAW file extensions
  • Languages:
    • Updated Czech translation
    • Updated Dutch translation (thanks, leroy!)
    • Updated Spanish translation (thanks, Alfredo Ramos and uman2k!)
  • External Components:
    • Updated MediaInfo for Windows to 0.7.63, which:
      • Adds H.265 (HEVC) support
      • Fixed some crashes with .mov files
      • Improved AVI support
    • Updated Netty to 3.6.6
    • Updated Thumbnailator to 0.4.4, which:
      • Fixes memory errors with the latest Java Runtimes
Upgrade Notes:
For versions prior to 1.5.0:
For all versions:
It is recommended (but usually not necessary) to delete your UMS.conf file prior to installing this version. Windows users can choose the "clean install" option while installing instead.
sanjeev
Re: Version 2.6.5 is released
Post by sanjeev »
Looking forward to test this version. Any luck with the mencoder issues reported in 2.6.4 ?
Thanks for the quick release cycle !
Wolfgan
Post by Wolfgan »
Thanks for the release. Looking at the changelog at github it's not clear to me if these enhancements went already to 3.0a1 or if a 3.0a2 is expected to release soon?
Thanks! Wolf
Sunwind
Post by Sunwind »
Wolfgan wrote:Thanks for the release. Looking at the changelog at github it's not clear to me if these enhancements went already to 3.0a1 or if a 3.0a2 is expected to release soon?
Thanks! Wolf
Wondering this as well
These enhancements aren't in 3.0a1, a2 should be released soon
Sunwind
Post by Sunwind »
I had to go back to 3.0a1 because 2.6.5 won't play any of my anime .mkv files h264-720p / 1080p 10 bit FLAC. plays fine in the alpha.
Wolfgan
Post by Wolfgan »
SubJunk wrote:These enhancements aren't in 3.0a1, a2 should be released soon
Looking forward to it. Thanks!
Wolfgan
Post by Wolfgan »
Sunwind wrote:I had to go back to 3.0a1 because 2.6.5 won't play any of my anime .mkv files h264-720p / 1080p 10 bit FLAC. plays fine in the alpha.
Looking at github changelog it seems 3.0a2 is coming soon! yeah!
