[Solved] Can't Play Music after Installing 5.1.1
Re: Can't Play Music after Installing 5.1.1.2 2nd Update
I tried the 2nd update for UMS 5.1.1.1 with the same results: Some mp3's played but most did not show in the list. mediainfo.dll 0.7.71.0 does now show up though.
Trace enclosed.
Trace enclosed.
- (39.62 KiB) Downloaded 635 times
Hi
You can try to delete all ext on the line "streamextentions" except mp3 in the "renderer.conf".
Tell me if that s working.
I have just loaded 5.1.1.1 and can confirm mediainfo is successfully loaded and my Music files are now being recognised on the PS3. Many thanks for the timely update.
DEBUG 07:15:12.653 [main] Tue Apr 07 07:15:12 NZST 2015
DEBUG 07:15:12.654 [main] Reading cred.path: "C:\ProgramData\UMS\UMS.cred" (default: "")
DEBUG 07:15:13.054 [main] PID: 4676
DEBUG 07:15:13.058 [main]
INFO 07:15:13.058 [main] Starting Universal Media Server 5.1.1.1
INFO 07:15:13.058 [main] Based on PS3 Media Server by shagrath, copyright 2008-2014
INFO 07:15:13.058 [main] http://www.universalmediaserver.com
INFO 07:15:13.059 [main]
INFO 07:15:13.059 [main] Build: a00ebf2a5 (2015-04-02)
INFO 07:15:13.059 [main] Java: Java HotSpot(TM) Client VM 1.8.0_31 32-bit by Oracle Corporation
INFO 07:15:13.059 [main] OS: Windows 8.1 64-bit 6.3
INFO 07:15:13.059 [main] Encoding: UTF-8
INFO 07:15:13.062 [main] Memory: 742 MB
INFO 07:15:13.062 [main] Language: en
INFO 07:15:13.062 [main] Working directory: C:\Program Files (x86)\Universal Media Server
INFO 07:15:13.064 [main] Temp directory: C:\Users\Office\AppData\Local\Temp\universalmediaserver
INFO 07:15:13.066 [main] Logging config file: C:\Program Files (x86)\Universal Media Server\logback.xml
INFO 07:15:13.066 [main] debug.log: C:\ProgramData\UMS\debug.log
INFO 07:15:13.066 [main] Profile directory: C:\ProgramData\UMS
INFO 07:15:13.068 [main] Profile directory permissions: rw
INFO 07:15:13.068 [main] Profile path: C:\ProgramData\UMS\UMS.conf
INFO 07:15:13.069 [main] Profile permissions: rw
INFO 07:15:13.070 [main] Profile name: Office-PC
DEBUG 07:15:13.070 [main] Reading web_conf: "C:\ProgramData\UMS\WEB.conf" (previous: null, default: "C:\ProgramData\UMS\WEB.conf")
INFO 07:15:13.070 [main] Web conf path: C:\ProgramData\UMS\WEB.conf
INFO 07:15:13.071 [main] Web conf permissions: rw
DEBUG 07:15:13.083 [main] Reading run_wizard: false (default: true)
DEBUG 07:15:13.197 [pool-1-thread-1] Reading auto_update: true (default: false)
DEBUG 07:15:13.547 [main] Reading minimized: true (default: false)
DEBUG 07:15:13.555 [main] Reading hide_advanced_options: false (default: true)
DEBUG 07:15:13.555 [main] Reading server_name: "Office" (default: "Universal Media Server")
DEBUG 07:15:13.626 [main] Reading renderer_default: "PlayStation 3" (default: "")
DEBUG 07:15:13.645 [main] Reading maximum_bitrate: "0" (default: "90")
DEBUG 07:15:13.646 [main] Reading automatic_maximum_bitrate: true (default: false)
DEBUG 07:15:13.647 [main] Reading prevents_sleep_mode: true (default: false)
INFO 07:15:13.648 [main] Loading renderer names from C:\Program Files (x86)\Universal Media Server\renderers
DEBUG 07:15:13.656 [main] Added file watch at renderers: renderers\\Apple-iDevice-AirPlayer.conf
DEBUG 07:15:13.658 [main] Added file watch at renderers: renderers\\Apple-iDevice.conf
DEBUG 07:15:13.659 [main] Added file watch at renderers: renderers\\BlackBerry-PlayBook-KalemSoftMP.conf
INFO 07:15:13.661 [main] Loading MediaInfo library
INFO 07:15:13.773 [main] Loaded MediaInfoLib - v0.7.71
DEBUG 07:15:13.774 [main] Option 'File_TestContinuousFileNames' is set to: 0
DEBUG 07:15:13.774 [main] Option 'ParseSpeed' is set to: 0.000
Adding "StreamExtensions = mp3" to "Sony-PlayStation3.conf" did not change anything. Most of the mp3 files could would not show up.jps92 wrote:Hi
I tried accessing a backup copy of my music on another drive. They were all accessible and played OK! I looked to see if it may be a permissions issue and matched the permissions of the backup to the original from the top folder down. However, it did not make any difference, even though all users have read/write/execute permissions to all folders and files. I still think it may be a permissions issue preventing UMS and/or mediainfo from reading the files.
I'd like to find out whether a particular piece of code has any bearing on this issue, so if you would please test this update and let me know what if anything happens, thxsenpai46 wrote:However, it did not make any difference
Thx for testing, looks like there was a glitch in the update, will redo. PS let's keep the discussion in this threadsenpai46 wrote:I tested it. It did not even get to the point of finding the PS3. (See enclosed)
I removed the update and it found the PS3. However, I had to to click on "Restart Server" after getting the same java errors to get it to work.
Clicking on "Restart Server" multiple times with the update.jar did not work to link to the PS3. I tested in "administration" mode with the same results.
Is there a way to turn on Trace at UMS startup?
If you need more info or would like me to do more testing please let me know.
I tested the update again in windows using 5.1.1.1 and it worked ok, so not sure how you got that error. I rebuilt it anyway, just in case. Could you please test the new one with a clean install of 5.1.1.1, just so we eliminate any extraneous factors?senpai46l wrote:I tested it. It did not even get to the point of finding the PS3. (See enclosed)
The update.jar appears to work OK. However, it also worked OK without it this time! I did a clean install of UMS 5.1.1.1. I was able to access all of my music mp3's and wma's in the folder that would either hide some of the files or would not play them. I had rebooted my PC before the install only because it locked up on me. I suspect there may have been a Windows 7 glitch that rebooting cleared up. Anyway, enclosed are two trace files, one with and one without update.jar added.infidel wrote:I tested the update again in windows using 5.1.1.1 and it worked ok, so not sure how you got that error. I rebuilt it anyway, just in case. Could you please test the new one with a clean install of 5.1.1.1, just so we eliminate any extraneous factors?senpai46l wrote:I tested it. It did not even get to the point of finding the PS3. (See enclosed)
I am sorry that the results could not be more conclusive.
On the contrary very conclusive (in confirming that the issue wasn't related to the code in question), plus we lucked-out and accidentally resolved your issue, which isn't badsenpai46 wrote:The update.jar appears to work OK. However, it also worked OK without it this time! I did a clean install... sorry that the results could not be more conclusive.
Re: [Solved] Can't Play Music after Installing 5.1.1
i had the same issue, i found out i installed the UMS 5.1.1.1 Java 8 but my java plugin was 1.7
after installing the correct version it works
