ffmpeg has a return code of 139
- Optimus_prime
Re: ffmpeg has a return code of 139
Yes i can test it for you. Either send me a dropbox link or something similar
My system is 10.8.4 on a VMware virtual machine (6GB Ram allocated, 2 Processors)(VMWare Workstation 11.0.0 build-2305329)
Netbeans 8.0.2 with Java 6 / 7 / 8 (thats right all versions)
Xcode 5.x.x (not sure off the top of my head but it's the latest for 10.8.4)
.dmgCreator (to create the .dmg's for Java 7/8)
Nothing much after this, I have played around in trying to build ffMpeg before but not luck in including all the libraries and getting it to build properly, but that was on another VM.
OK - sounds good - latest is what they look for, Xcode 4.6.3 was for 10.7.5 but the "Note" may apply for any version.
Attached are my build notes edited after completion. There were a few iterations trying to resolve some of the errors. Not sure exactly which operation fixed each. You code, so I assume you can follow the terse HowTo.
Let me know any problems/fixes so I can document for others.
thanx
thanx
BuildNotes_ffmpeg.txt
- (3.96 KiB) Downloaded 794 times
. . . . and a few others.
Samsung UN55C8000
Samsung UN55C8000
Building: ffmpeg
Played around more with the long option list from https://evermeet.cx/ffmpeg/ - had to convert to "with"…
Got it built but without three options: --with-libvpx --with-avisynth --with-gpl
Still building 15.8 MB.
build command:
snippet from debug.log:I don't know enough to tell if all the libs really are in there but I like the chatter from it - more info is never bad.
one error: File '/Users/umsmkv/Library/Application Support/UMS/ffmpeg.webfilters' does not exist
Enjoy
build command:
brew install ffmpeg --with-fdk-aac --with-ffplay --with-freetype --with-libass --with-libquvi --with-libvorbis --with-opus --with-x265 --with-fontconfig --with-libass --with-libbluray --with-libfreetype --with-libgsm --with-libmodplug --with-libmp3lame --with-libopencore-amrnb --with-libopencore-amrwb --with-libopus --with-libschroedinger --with-libsoxr --with-libspeex --with-libtheora --with-libvidstab --with-libvo-aacenc --with-libvo-amrwbenc --with-libvorbis --with-libwavpack --with-libx264 --with-libx265 --with-libxavs --with-libxvid --with-libzmq --with-version3 --without-ffplay --without-indev=qtkit --without-indev=x11grab_xcb
DEBUG 00:32:13.607 [ffmpeg-1] Starting /Users/umsmkv/UMS_J8/ums_OSX-Java8_x2/target/ums-5.1.2_x2-distribution/UMS-x4.app/Contents/Resources/osx/ffmpeg -y -f lavfi -i nullsrc=s=720x480:d=1:r=1 -vf ass=DummyInput.ass -target ntsc-dvd -
TRACE 00:32:13.608 [ffmpeg-1] Setting FONTCONFIG_PATH to "/Users/umsmkv/UMS_J8/ums_OSX-Java8_x2/target/ums-5.1.2_x2-distribution/UMS-x4.app/Contents/Resources/fonts"
TRACE 00:32:13.608 [mplayer-0] Setting FONTCONFIG_PATH to "/Users/umsmkv/UMS_J8/ums_OSX-Java8_x2/target/ums-5.1.2_x2-distribution/UMS-x4.app/Contents/Resources/fonts"
INFO 00:32:13.617 [main] Searching for plugins in /Users/umsmkv/UMS_J8/ums_OSX-Java8_x2/target/ums-5.1.2_x2-distribution/UMS-x4.app/Contents/Resources/plugins
INFO 00:32:13.619 [main] No plugins found
TRACE 00:32:13.708 [ffmpeg-1] Successfully initialized buffer to 52,428,800 bytes.
TRACE 00:32:13.721 [mplayer-0] Successfully initialized buffer to 52,428,800 bytes.
DEBUG 00:32:13.722 [ffmpeg-1] Attaching thread: ffmpeg-1
DEBUG 00:32:13.722 [mplayer-0] Attaching thread: mplayer-0
DEBUG 00:32:13.723 [mplayer-0] Unix process ID (/Users/umsmkv/UMS_J8/ums_OSX-Java8_x2/target/ums-5.1.2_x2-distribution/UMS-x4.app/Contents/Resources/osx/mplayer): 82870
DEBUG 00:32:13.723 [ffmpeg-1] Unix process ID (/Users/umsmkv/UMS_J8/ums_OSX-Java8_x2/target/ums-5.1.2_x2-distribution/UMS-x4.app/Contents/Resources/osx/ffmpeg): 82869
INFO 00:32:13.735 [main] Registering transcoding engine: FFmpeg Audio
DEBUG 00:32:13.743 [mplayer-0-2] Can't init Apple Remote.
INFO 00:32:13.745 [main] Registering transcoding engine: MEncoder
INFO 00:32:13.745 [main] Registering transcoding engine: FFmpeg
INFO 00:32:13.747 [main] Registering transcoding engine: VLC
DEBUG 00:32:13.750 [main] Error reading ffmpeg web filters: File '/Users/umsmkv/Library/Application Support/UMS/ffmpeg.webfilters' does not exist
DEBUG 00:32:13.896 [ffmpeg-1-2] ffmpeg version 2.6.2 Copyright (c) 2000-2015 the FFmpeg developers
DEBUG 00:32:13.896 [ffmpeg-1-2] built with Apple LLVM version 4.2 (clang-425.0.28) (based on LLVM 3.2svn)
DEBUG 00:32:13.897 [ffmpeg-1-2] configuration: --prefix=/usr/local/Cellar/ffmpeg/2.6.2 --enable-static --enable-pthreads --enable-gpl --enable-version3 --enable-hardcoded-tables --enable-avresample --cc=clang --host-cflags= --host-ldflags= --enable-libmp3lame --enable-libvo-aacenc --enable-libx264 --enable-libxvid --enable-libfdk-aac --enable-ffplay --enable-libfontconfig --enable-libfreetype --enable-libass --enable-libquvi --enable-libsoxr --enable-libvidstab --enable-libvorbis --enable-libopus --enable-libx265 --disable-indev=x11grab_xcb --enable-nonfree --enable-vda
DEBUG 00:32:13.897 [ffmpeg-1-2] libavutil 54. 20.100 / 54. 20.100
DEBUG 00:32:13.897 [ffmpeg-1-2] libavcodec 56. 26.100 / 56. 26.100
DEBUG 00:32:13.897 [ffmpeg-1-2] libavformat 56. 25.101 / 56. 25.101
DEBUG 00:32:13.897 [ffmpeg-1-2] libavdevice 56. 4.100 / 56. 4.100
DEBUG 00:32:13.897 [ffmpeg-1-2] libavfilter 5. 11.102 / 5. 11.102
DEBUG 00:32:13.897 [ffmpeg-1-2] libavresample 2. 1. 0 / 2. 1. 0
DEBUG 00:32:13.897 [ffmpeg-1-2] libswscale 3. 1.101 / 3. 1.101
DEBUG 00:32:13.897 [ffmpeg-1-2] libswresample 1. 1.100 / 1. 1.100
DEBUG 00:32:13.897 [ffmpeg-1-2] libpostproc 53. 3.100 / 53. 3.100
DEBUG 00:32:13.898 [main] FFmpeg supported protocols: [cache, concat, crypto, data, ffrtmphttp, file, ftp, gopher, hls, http, httpproxy, mmsh, mmst, pipe, rtmp, rtmpt, rtp, srtp, subfile, tcp, udp, udplite, unix, mms]
INFO 00:32:13.898 [main] Registering transcoding engine: FFmpeg Web Video
DEBUG 00:32:13.899 [ffmpeg-1-2] Input #0, lavfi, from 'nullsrc=s=720x480:d=1:r=1':
DEBUG 00:32:13.899 [ffmpeg-1-2] Duration: N/A, start: 0.000000, bitrate: N/A
DEBUG 00:32:13.899 [ffmpeg-1-2] Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p, 720x480 [SAR 1:1 DAR 3:2], 1 tbr, 1 tbn, 1 tbc
INFO 00:32:13.899 [main] Registering transcoding engine: MEncoder Web
INFO 00:32:13.899 [main] Registering transcoding engine: VLC Web Video
INFO 00:32:13.902 [main] Registering transcoding engine: tsMuxeR
INFO 00:32:13.902 [main] Registering transcoding engine: Audio High Fidelity
INFO 00:32:13.903 [main] Registering transcoding engine: VLC Web Audio (Legacy)
INFO 00:32:13.903 [main] Registering transcoding engine: VLC Web Video (Legacy)
INFO 00:32:13.904 [main] Registering transcoding engine: dcraw Thumbnailer
INFO 00:32:13.959 [main] Using address /10.0.1.50 found on network interface: name:en0 (en0)
INFO 00:32:13.960 [main] Created socket: /10.0.1.50:5001
DEBUG 00:32:13.988 [mplayer-0-2] File not found: 'dummy'
DEBUG 00:32:13.988 [mplayer-0-2] Failed to open dummy.
TRACE 00:32:13.990 [mplayer-0] EOF
TRACE 00:32:13.991 [mplayer-0] Ready to Stop: true
ERROR 00:32:14.023 [main] Another program is using port 5001, which UMS needs.
ERROR 00:32:14.023 [main] You can change the port UMS uses on the General Configuration tab.
TRACE 00:32:14.024 [main] The error was: org.jboss.netty.channel.ChannelException: Failed to bind to: /10.0.1.50:5001
DEBUG 00:32:14.068 [main] Sending ALIVE...
DEBUG 00:32:14.069 [ffmpeg-1-2] [Parsed_ass_0 @ 0x7fad18417ec0] Added subtitle file: 'DummyInput.ass' (6 styles, 1 events)
TRACE 00:32:14.069 [main] Sending message from multicast socket on network interface: name:0.0.0.0
TRACE 00:32:14.069 [main] Multicast socket is on interface: /0.0.0.0
TRACE 00:32:14.069 [main] Socket Timeout: 0
TRACE 00:32:14.070 [main] Socket TTL: 32
DEBUG 00:32:14.071 [main] Reading uuid: "3d7edd4a-31e0-4758-9169-eb3f39a36933" (default: null)
INFO 00:32:14.071 [main] Using the following UUID configured in UMS.conf: 3d7edd4a-31e0-4758-9169-eb3f39a36933
DEBUG 00:32:14.072 [ffmpeg-1-2] Output #0, dvd, to 'pipe:':
DEBUG 00:32:14.072 [ffmpeg-1-2] Metadata:
DEBUG 00:32:14.072 [ffmpeg-1-2] encoder : Lavf56.25.101
DEBUG 00:32:14.072 [ffmpeg-1-2] Stream #0:0: Video: mpeg2video, yuv420p, 720x480 [SAR 1:1 DAR 3:2], q=2-31, 6000 kb/s, 29.97 fps, 90k tbn, 29.97 tbc
DEBUG 00:32:14.072 [ffmpeg-1-2] encoder : Lavc56.26.100 mpeg2video
DEBUG 00:32:14.072 [ffmpeg-1-2] Stream mapping:
DEBUG 00:32:14.072 [ffmpeg-1-2] Stream #0:0 -> #0:0 (rawvideo (native) -> mpeg2video (native))
DEBUG 00:32:14.073 [ffmpeg-1-2] Press [q] to stop, [?] for help
TRACE 00:32:14.074 [main] Waiting 250 milliseconds...
DEBUG 00:32:14.080 [ffmpeg-1-2] frame= 1 fps=0.0 q=1.6 Lsize= 8kB time=00:00:00.03 bitrate=1964.1kbits/s
DEBUG 00:32:14.081 [ffmpeg-1-2] video:5kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 51.227615%
TRACE 00:32:14.087 [ffmpeg-1] EOF
TRACE 00:32:14.087 [ffmpeg-1] Ready to Stop: true
TRACE 00:32:14.327 [UPNPHelper] Setting multicast network interface: name:en0 (en0)
INFO 00:32:14.327 [main] The server is now available for renderers to find
DEBUG 00:32:16.493 [mplayer-0-Cleanup] Stopping Unix process 82870: mplayer-0
TRACE 00:32:16.493 [mplayer-0-Cleanup] Killing the Unix process: 82870
TRACE 00:32:16.495 [mplayer-0-Cleanup] Destroying buffer
DEBUG 00:32:16.589 [ffmpeg-1-Cleanup] Stopping Unix process 82869: ffmpeg-1
TRACE 00:32:16.589 [ffmpeg-1-Cleanup] Killing the Unix process: 82869
TRACE 00:32:16.589 [ffmpeg-1-Cleanup] Destroying buffer
Enjoy
Samsung UN55C8000
Samsung UN55C8000
error 133 fixed, now error 139
OK mate - it's done. Fixed the ffmpeg.webfilters error.
Ran into another error which you have seen before in another thread: viewtopic.php?t=2749
Here is the latest log of all the ffmpeg threads activity:I suspect it may have to do with the dyld: Library not loaded stuff - saw something similar in a google search "ffmpeg returns error 133": http://www.ps3mediaserver.org/forum/vie ... =7&t=13620
Maybe more diving into it later.
I've gone as far as I need to for now in pursuit of my media system. UMS far exceeds what I expected to find. These problems were minor and easy to fix.
I'd like to pass these mods up for others. Need info to merge into the current base and the push-pull process.
DEBUG 16:31:57.798 [ffmpeg-1] Starting /Users/umsmkv/UMS_J8/ums_OSX-Java8_x2/target/ums-5.1.2_x2-distribution/Universal Media Server.app/Contents/Resources/osx/ffmpeg -y -f lavfi -i nullsrc=s=720x480:d=1:r=1 -vf ass=DummyInput.ass -target ntsc-dvd -
DEBUG 16:31:57.919 [ffmpeg-1] Attaching thread: ffmpeg-1
DEBUG 16:31:57.921 [ffmpeg-1] Unix process ID (/Users/umsmkv/UMS_J8/ums_OSX-Java8_x2/target/ums-5.1.2_x2-distribution/Universal Media Server.app/Contents/Resources/osx/ffmpeg): 7010
DEBUG 16:31:57.925 [ffmpeg-1-2] dyld: Library not loaded: /usr/local/opt/freetype/lib/libfreetype.6.dylib
DEBUG 16:31:57.926 [ffmpeg-1-2] Referenced from: /Users/umsmkv/UMS_J8/ums_OSX-Java8_x2/target/ums-5.1.2_x2-distribution/Universal Media Server.app/Contents/Resources/osx/ffmpeg
DEBUG 16:31:57.926 [ffmpeg-1-2] Reason: no suitable image found. Did find:
DEBUG 16:31:57.926 [ffmpeg-1-2] /usr/local/opt/freetype/lib/libfreetype.6.dylib: not a file
INFO 16:31:58.136 [ffmpeg-1] Process /Users/umsmkv/UMS_J8/ums_OSX-Java8_x2/target/ums-5.1.2_x2-distribution/Universal Media Server.app/Contents/Resources/osx/ffmpeg has a return code of 133! Maybe an error occurred... check the log file
DEBUG 16:32:00.637 [ffmpeg-1-Cleanup] Stopping Unix process 7010: ffmpeg-1
Samsung UN55C8000
Samsung UN55C8000
READ FIRST : Don't build ffmpeg
OP - if you have not started the ffmpeg build - don't!!
I may have stumbled across the cause of the new error in libfreetype - it's in the filesystem and I don't know yet how it happened.
I have seen something similar to this earlier (not related to UMS, et al), it's nasty. A pic shows it better: this is my /usr/local … and explain this:
libfreetype.6.dylib actually lives here:
I need you to watch the /usr/local/opt path to see if freetype is created with something else, what it is and if it gets to this state of infinite loop. The fix for me is rather simple but I don't know what got clobbered and last time it scribbled this link junk in all of my home directories, two levels deep!
thanx
Last login: Tue May 26 07:48:23 on ttys010
ksh:
: ____Elm: ~ ; cd /usr/local/opt/freetype/lib/libfreetype.6.dylib
: ____Elm: libfreetype.6.dylib ; ls -al
total 400
drwxr-xr-x 27 sysadmin admin 918 May 24 01:08 .
drwxrwxr-x 27 root admin 918 May 20 23:02 ..
lrwxr-xr-x 1 sysadmin admin 21 May 20 23:10 cmake -> ../Cellar/cmake/3.2.2
lrwxr-xr-x 1 sysadmin admin 23 May 20 23:05 fdk-aac -> N????r A???PH??
lrwxr-xr-x 1 sysadmin admin 22 May 24 01:08 ffmpeg -> ../Cellar/ffmpeg/2.6.2
lrwxr-xr-x 1 sysadmin admin 27 May 23 14:06 fontconfig -> ../Cellar/fontconfig/2.11.1
lrwxr-xr-x 1 sysadmin admin 24 May 23 17:32 freetype ->
lrwxr-xr-x 1 sysadmin admin 24 May 23 14:06 fribidi -> ???????)??ģ????!?A5>???
lrwxr-xr-x 1 sysadmin admin 21 May 20 20:01 lame -> ../Cellar/lame/3.99.5
lrwxr-xr-x 1 sysadmin admin 23 May 20 23:03 libass -> ../Cellar/libass/0.12.1
lrwxr-xr-x 1 sysadmin admin 22 May 20 20:02 libogg -> ../Cellar/libogg/1.3.2
lrwxr-xr-x 1 sysadmin admin 23 May 23 14:06 libpng -> ??????:???????W??J??c?
lrwxr-xr-x 1 sysadmin admin 25 May 20 23:06 libquvi ->
lrwxr-xr-x 1 sysadmin admin 23 May 24 00:14 libsoxr -> ../Cellar/libsoxr/0.1.1
lrwxr-xr-x 1 sysadmin admin 26 May 24 00:14 libvidstab -> ../Cellar/libvidstab/0.98b
lrwxr-xr-x 1 sysadmin admin 28 May 20 20:01 libvo-aacenc -> ../Cellar/libvo-aacenc/0.1.3
lrwxr-xr-x 1 sysadmin admin 25 May 20 20:03 libvorbis -> ??N
lrwxr-xr-x 1 sysadmin admin 21 May 23 14:06 lua -> ??????
lrwxr-xr-x 1 sysadmin admin 18 May 20 23:05 opus -> ../Cellar/opus/1.1
lrwxr-xr-x 1 sysadmin admin 25 May 20 20:00 pkg-config -> ../Cellar/pkg-config/0.28
lrwxr-xr-x 1 sysadmin admin 20 May 20 23:04 sdl -> ../Cellar/sdl/1.2.15
lrwxr-xr-x 1 sysadmin admin 24 May 20 20:00 texi2html -> ???}?aL??a?E%?e??{&?????
lrwxr-xr-x 1 sysadmin admin 20 May 20 20:01 x264 -> ../Cellar/x264/r2533
lrwxr-xr-x 1 sysadmin admin 18 May 20 23:11 x265 -> python-format??msg
lrwxr-xr-x 1 sysadmin admin 20 May 20 20:01 xvid -> ../Cellar/xvid/1.3.3
lrwxr-xr-x 1 sysadmin admin 18 May 20 20:01 xz -> 9
lrwxr-xr-x 1 sysadmin admin 20 May 20 20:00 yasm -> ?
: ____Elm: libfreetype.6.dylib ; cd /usr/local/opt/freetype/
: ____Elm: freetype ; cd lib
-/bin/ksh: cd: lib: [No such file or directory]
: ____Elm: freetype ; cd /usr/local/opt/freetype/lib/
: ____Elm: lib ; pwd
: ____Elm: lib ; history |tail -7
1413 cd /usr/local/opt/freetype/lib/libfreetype.6.dylib
1414 ls -al
1415 cd /usr/local/opt/freetype/
1416 cd lib
1417 cd /usr/local/opt/freetype/lib/
1418 pwd
1419 history |tail -7
: ____Elm: lib ;
: ____Elm: local ; find -x . -name libfreetype.6.dylib -ls
8674274 1120 -r--r--r-- 1 sysadmin admin 569396 May 20 20:02 ./Cellar/freetype/2.5.5/lib/libfreetype.6.dylib
: ____Elm: local ;
thanx
Samsung UN55C8000
Samsung UN55C8000
Udate: UMS ffmpeg runs error free
Good news - Bad news.
Good - UMS nows launches error free after I removed the garbage /usr/local/opt stuff. The links were restored in opt for libfreetype.6.dylib, libfontconfig.1.dylib and libpng16.16.dylib. The startup:I don't know if it transcodes correctly since all my videos (it's all we do) pass straight through.
Bad - attempted to rebuild ffmpeg in hopes of reconstructing the opt tree but this ffmpeg build environment is self destructing right in front of me. There are too many new scripting languages to keep track of and learn to debug this convoluted mess, so I shall just leave it for now and let those better than me figure it out.
I will share what I have done but am now on to the RUI part of my system.
Thanx OP for the help.
[ffmpeg-1] Setting FONTCONFIG_PATH to "/Users/umsmkv/UMS_J8/ums_OSX-Java8_x2/target/ums-5.1.2_x2-distribution/Universal Media Server.app/Contents/Resources/fonts"
[mplayer-0] Starting /Users/umsmkv/UMS_J8/ums_OSX-Java8_x2/target/ums-5.1.2_x2-distribution/Universal Media Server.app/Contents/Resources/osx/mplayer dummy
[mplayer-0] Setting FONTCONFIG_PATH to "/Users/umsmkv/UMS_J8/ums_OSX-Java8_x2/target/ums-5.1.2_x2-distribution/Universal Media Server.app/Contents/Resources/fonts"
[main] Searching for plugins in /Users/umsmkv/UMS_J8/ums_OSX-Java8_x2/target/ums-5.1.2_x2-distribution/Universal Media Server.app/Contents/Resources/plugins
[ffmpeg-1] Unix process ID (/Users/umsmkv/UMS_J8/ums_OSX-Java8_x2/target/ums-5.1.2_x2-distribution/Universal Media Server.app/Contents/Resources/osx/ffmpeg): 34719
[mplayer-0] Unix process ID (/Users/umsmkv/UMS_J8/ums_OSX-Java8_x2/target/ums-5.1.2_x2-distribution/Universal Media Server.app/Contents/Resources/osx/mplayer): 34720
[mplayer-0] EOF
[main] Reading ffmpeg_webfilters_path: "/Users/umsmkv/Library/Application Support/UMS/ffmpeg.webfilters" (default: null)
[main] *** <FFmpegWebVideo({})
[ffmpeg-1-2] [Parsed_ass_0 @ 0x7fa61ae00a80] Added subtitle file: 'DummyInput.ass' (6 styles, 1 events)
[main] WEB interface is available at: http://10.0.1.50:9001
[ffmpeg-1] EOF
[mplayer-0-Cleanup] Stopping Unix process 34720: mplayer-0
[mplayer-0-Cleanup] Killing the Unix process: 34720
[ffmpeg-1-Cleanup] Stopping Unix process 34719: ffmpeg-1
[ffmpeg-1-Cleanup] Killing the Unix process: 34719
: ____Elm sysadmin/ ; brew install ffmpeg --with-fdk-aac --with-ffplay --with-freetype --with-libass --with-libquvi --with-libvorbis --with-opus --with-x265 --with-fontconfig --with->
exec /usr/local/Library/brew.rb install ffmpeg --with-fdk-aac --with-ffplay --with-freetype --with-libass --with-libquvi --with-libvorbis --with-opus --with-x265 --with-fontconfig --with-libass --with-libbluray --with-libfreetype --with-libgsm --with-libmodplug --with-libmp3lame --with-libopencore-amrnb --with-libopencore-amrwb --with-libopus --with-libschroedinger --with-libsoxr --with-libspeex --with-libtheora --with-libvidstab --with-libvo-aacenc --with-libvo-amrwbenc --with-libvorbis --with-libwavpack --with-libx264 --with-libx265 --with-libxavs --with-libxvid --with-libzmq --with-version3 --without-ffplay --without-indev=qtkit --without-indev=x11grab_xcb
Error: You must `brew link xz lua' before ffmpeg can be installed
: ____Elm sysadmin/ ; brew link xz lua
exec /usr/local/Library/brew.rb link xz lua
Error: pathname contains \0: "\a\003\000\000\016\024\000\000\360\b\001\000\000\000\000\000\321\000\000\000\017"
Linking /usr/local/Cellar/xz/5.2.1... Please report this bug:
https://git.io/brew-troubleshooting
/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8/pathname.rb:215:in `initialize'
/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8/pathname.rb:823:in `new'
/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8/pathname.rb:823:in `readlink'
/usr/local/Library/Homebrew/extend/pathname.rb:286:in `resolved_path'
/usr/local/Library/Homebrew/keg.rb:365:in `make_relative_symlink'
/usr/local/Library/Homebrew/keg.rb:312:in `link'
/usr/local/Library/Homebrew/cmd/link.rb:38:in `link'
/usr/local/Library/Homebrew/keg.rb:214:in `lock'
/usr/local/Library/Homebrew/formula_lock.rb:29:in `with_lock'
/usr/local/Library/Homebrew/cmd/link.rb:33:in `link'
/usr/local/Library/Homebrew/cmd/link.rb:12:in `each'
/usr/local/Library/Homebrew/cmd/link.rb:12:in `link'
/usr/local/Library/brew.rb:140:in `send'
Samsung UN55C8000
Samsung UN55C8000
- Optimus_prime
Wow, your a machine. What help.......your doing it all yourself. I've tried to build ffmpeg before from scratch without using any brew's. But it always came out with errors i couldn't fix, but i'll have another go soon unless you get a version working for me to test out. If you keep listing all your issues and fixes here i can follow what you've done. Good work mate and when you can share a link for me to download and test that would be great.
YupOptimus_prime wrote:Wow, your a machine. What help.......your doing it all yourself.
Same-same here - it's why I went brewI've tried to build ffmpeg before from scratch without using any brew's. But it always came out with errors i couldn't fix
I don't have a parking lot for itbut i'll have another go soon unless you get a version working for me to test out. Good work mate and when you can share a link for me to download and test that would be great.
can do - just need a little help with the push-pull process and more importantly the merge process - I am still on the 5.1.2 baseIf you keep listing all your issues and fixes here i can follow what you've done.
Samsung UN55C8000
Samsung UN55C8000
What broke?
Is the backing tree broke?
I see this: This is a fresh, virgin clone of 5.1.3 osx build:
The build broke on:
I disabled it and: … a lot more errors.
The environment seemed to degrade over the last 24hours an I can't build 5.1.2 or 5.1.3.
Is there a forum/post/log for the state of the backing tree, report problems, … ?
Nothing I can do now but wait.
cd /Users/umsmkv/UMS_J8/ums-OSX-513J8; JAVA_HOME=/Library/Java/JavaVirtualMachines/jdk1.8.0_45.jdk/Contents/Home "/Applications/NetBeans/NetBeans 8.0.2.app/Contents/Resources/NetBeans/java/maven/bin/mvn" -Posx clean install
Scanning for projects...
Building Universal Media Server 5.1.3
Downloading: http://4thline.org/m2/net/coobird/thumbnailator/maven-metadata.xml
Could not transfer metadata net.coobird:thumbnailator/maven-metadata.xml from/to 4thline-repo (http://4thline.org/m2): Failed to transfer file: http://4thline.org/m2/net/coobird/thumbnailator/maven-metadata.xml. Return code is: 502 , ReasonPhrase:Proxy Error.
Downloading: http://4thline.org/m2/org/slf4j/slf4j-api/maven-metadata.xml
Could not transfer metadata org.slf4j:slf4j-api/maven-metadata.xml from/to 4thline-repo (http://4thline.org/m2): Failed to transfer file: http://4thline.org/m2/org/slf4j/slf4j-api/maven-metadata.xml. Return code is: 502 , ReasonPhrase:Proxy Error.
--- maven-clean-plugin:2.4.1:clean (default-clean) @ ums ---
Deleting /Users/umsmkv/UMS_J8/ums-OSX-513J8/target
--- maven-external-dependency-plugin:0.5:clean-external (clean-external-dependencies) @ ums ---
starting to clean external dependency staged files
finished cleaning external dependency staged files
--- maven-external-dependency-plugin:0.5:resolve-external (resolve-install-external-dependencies) @ ums ---
starting to resolve external dependencies
attempting to resolve external artifact: sevenzip:jbinding:4.65-1.04-RC:jar
external artifact resolved in existing repository; no download needed: sevenzip:jbinding:4.65-1.04-RC:jar
attempting to resolve external artifact: sevenzip-allplatforms:jbinding-allplatforms:4.65-1.04-RC:jar
external artifact resolved in existing repository; no download needed: sevenzip-allplatforms:jbinding-allplatforms:4.65-1.04-RC:jar
attempting to resolve external artifact: jwbroek.cuelib:cuelib:1.2.1-2008-06-13:jar
external artifact resolved in existing repository; no download needed: jwbroek.cuelib:cuelib:1.2.1-2008-06-13:jar
attempting to resolve external artifact: mediautil:mediautil:1.0:jar
external artifact resolved in existing repository; no download needed: mediautil:mediautil:1.0:jar
finished resolving all external dependencies
--- maven-external-dependency-plugin:0.5:install-external (resolve-install-external-dependencies) @ ums ---
starting to install external dependencies into local repository
resolving artifact for installation: sevenzip:jbinding:4.65-1.04-RC:jar
this aritifact already exists in the local repository; no download is needed: sevenzip:jbinding:4.65-1.04-RC:jar
resolving artifact for installation: sevenzip-allplatforms:jbinding-allplatforms:4.65-1.04-RC:jar
this aritifact already exists in the local repository; no download is needed: sevenzip-allplatforms:jbinding-allplatforms:4.65-1.04-RC:jar
resolving artifact for installation: jwbroek.cuelib:cuelib:1.2.1-2008-06-13:jar
this aritifact already exists in the local repository; no download is needed: jwbroek.cuelib:cuelib:1.2.1-2008-06-13:jar
resolving artifact for installation: mediautil:mediautil:1.0:jar
this aritifact already exists in the local repository; no download is needed: mediautil:mediautil:1.0:jar
finished installing all external dependencies into local repository
--- git-commit-id-plugin:2.1.13:revision (default) @ ums ---
--- maven-resources-plugin:2.5:resources (default-resources) @ ums ---
[debug] execute contextualize
Using 'UTF-8' encoding to copy filtered resources.
Copying 228 resources to resources
Copying 1 resource to resources
Copying 1 resource to ..
--- maven-compiler-plugin:3.2:compile (default-compile) @ ums ---
Changes detected - recompiling the module!
Compiling 261 source files to /Users/umsmkv/UMS_J8/ums-OSX-513J8/target/classes
/Users/umsmkv/UMS_J8/ums-OSX-513J8/src/main/java/net/pms/dlna/DLNAResource.java: Some input files use or override a deprecated API.
/Users/umsmkv/UMS_J8/ums-OSX-513J8/src/main/java/net/pms/dlna/DLNAResource.java: Recompile with -Xlint:deprecation for details.
/Users/umsmkv/UMS_J8/ums-OSX-513J8/src/main/java/net/pms/network/UPNPControl.java: Some input files use unchecked or unsafe operations.
/Users/umsmkv/UMS_J8/ums-OSX-513J8/src/main/java/net/pms/network/UPNPControl.java: Recompile with -Xlint:unchecked for details.
--- maven-resources-plugin:2.5:testResources (default-testResources) @ ums ---
Copying 12 resources to net/pms/util
--- maven-compiler-plugin:3.2:testCompile (default-testCompile) @ ums ---
Compiling 17 source files to /Users/umsmkv/UMS_J8/ums-OSX-513J8/target/test-classes
--- maven-surefire-plugin:2.18:test (default-test) @ ums ---
Surefire report directory: /Users/umsmkv/UMS_J8/ums-OSX-513J8/target/surefire-reports
T E S T S
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option UseSplitVerifier; support was removed in 8.0
Running net.pms.configuration.RendererConfigurationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.204 sec - in net.pms.configuration.RendererConfigurationTest
Running net.pms.dlna.DLNAMediaAudioTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec - in net.pms.dlna.DLNAMediaAudioTest
Running net.pms.dlna.DLNAMediaSubtitleTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.129 sec - in net.pms.dlna.DLNAMediaSubtitleTest
Running net.pms.dlna.LibMediaInfoParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec - in net.pms.dlna.LibMediaInfoParserTest
Running net.pms.formats.v2.AudioAttributeTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec - in net.pms.formats.v2.AudioAttributeTest
Running net.pms.formats.v2.AudioPropertiesTest
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec - in net.pms.formats.v2.AudioPropertiesTest
Running net.pms.formats.v2.SubtitleTypeTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec - in net.pms.formats.v2.SubtitleTypeTest
Running net.pms.formats.v2.SubtitleUtilsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec - in net.pms.formats.v2.SubtitleUtilsTest
Running net.pms.test.formats.FormatFactoryTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec - in net.pms.test.formats.FormatFactoryTest
Running net.pms.test.formats.FormatRecognitionTest
Tests run: 9, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.835 sec <<< FAILURE! - in net.pms.test.formats.FormatRecognitionTest
testBackwardsCompatibility(net.pms.test.formats.FormatRecognitionTest) Time elapsed: 0.068 sec <<< FAILURE!
java.lang.AssertionError: isCompatible() gives same outcome as ps3compatible() for MKV expected:<false> but was:<true>
at org.junit.Assert.fail(Assert.java:88)
at org.junit.Assert.failNotEquals(Assert.java:834)
at org.junit.Assert.assertEquals(Assert.java:118)
at net.pms.test.formats.FormatRecognitionTest.testBackwardsCompatibility(FormatRecognitionTest.java:297)
Running net.pms.test.formats.FormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec - in net.pms.test.formats.FormatTest
Running net.pms.test.Iso639Test
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec - in net.pms.test.Iso639Test
Running net.pms.test.TaskRunnerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.01 sec - in net.pms.test.TaskRunnerTest
Running net.pms.util.FileUtilTest
Tests run: 27, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.053 sec - in net.pms.util.FileUtilTest
Running net.pms.util.PlayerUtilTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.03 sec - in net.pms.util.PlayerUtilTest
Running net.pms.util.VersionTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec - in net.pms.util.VersionTest
Results :
Failed tests:
FormatRecognitionTest.testBackwardsCompatibility:297 isCompatible() gives same outcome as ps3compatible() for MKV expected:<false> but was:<true>
Tests run: 117, Failures: 1, Errors: 0, Skipped: 0
BUILD FAILURE
Total time: 48.799s
Finished at: Fri May 29 08:31:01 EDT 2015
Final Memory: 36M/653M
Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.18:test (default-test) on project ums: There are test failures.
Please refer to /Users/umsmkv/UMS_J8/ums-OSX-513J8/target/surefire-reports for the individual test results.
-> [Help 1]
To see the full stack trace of the errors, re-run Maven with the -e switch.
Re-run Maven using the -X switch to enable full debug logging.
For more information about the errors and possible solutions, please read the following articles:
[Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
Failed tests:
cd /Users/umsmkv/UMS_J8/ums-OSX-513J8; JAVA_HOME=/Library/Java/JavaVirtualMachines/jdk1.8.0_45.jdk/Contents/Home "/Applications/NetBeans/NetBeans 8.0.2.app/Contents/Resources/NetBeans/java/maven/bin/mvn" -Posx install
Nothing to compile - all classes are up to date
T E S T S
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.203 sec - in net.pms.configuration.RendererConfigurationTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.115 sec - in net.pms.dlna.DLNAMediaSubtitleTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec - in net.pms.dlna.LibMediaInfoParserTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec - in net.pms.formats.v2.AudioAttributeTest
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec - in net.pms.formats.v2.AudioPropertiesTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec - in net.pms.formats.v2.SubtitleTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec - in net.pms.test.formats.FormatFactoryTest
Tests run: 9, Failures: 0, Errors: 9, Skipped: 0, Time elapsed: 0.019 sec <<< FAILURE! - in net.pms.test.formats.FormatRecognitionTest
testPlaystationImageTiffCompatibility(net.pms.test.formats.FormatRecognitionTest) Time elapsed: 0.012 sec <<< ERROR!
java.lang.ExceptionInInitializerError: null
at net.pms.test.formats.FormatRecognitionTest.<clinit>(FormatRecognitionTest.java:25)
testPlaystationImagePngCompatibility(net.pms.test.formats.FormatRecognitionTest) Time elapsed: 0 sec <<< ERROR!
java.lang.NoClassDefFoundError: Could not initialize class net.pms.test.formats.FormatRecognitionTest
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:422)
at org.junit.runners.BlockJUnit4ClassRunner.createTest(BlockJUnit4ClassRunner.java:217)
at org.junit.runners.BlockJUnit4ClassRunner$1.runReflectiveCall(BlockJUnit4ClassRunner.java:266)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
at org.junit.runners.BlockJUnit4ClassRunner.methodBlock(BlockJUnit4ClassRunner.java:263)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
at org.apache.maven.surefire.junit4.JUnit4Provider.execute(JUnit4Provider.java:283)
at org.apache.maven.surefire.junit4.JUnit4Provider.executeWithRerun(JUnit4Provider.java:173)
at org.apache.maven.surefire.junit4.JUnit4Provider.executeTestSet(JUnit4Provider.java:153)
at org.apache.maven.surefire.junit4.JUnit4Provider.invoke(JUnit4Provider.java:128)
at org.apache.maven.surefire.booter.ForkedBooter.invokeProviderInSameClassLoader(ForkedBooter.java:203)
at org.apache.maven.surefire.booter.ForkedBooter.runSuitesInProcess(ForkedBooter.java:155)
at org.apache.maven.surefire.booter.ForkedBooter.main(ForkedBooter.java:103)
testPlaystationVideoMpgCompatibility(net.pms.test.formats.FormatRecognitionTest) Time elapsed: 0.001 sec <<< ERROR!
testPlaystationAudioMp3Compatibility(net.pms.test.formats.FormatRecognitionTest) Time elapsed: 0.002 sec <<< ERROR!
testRendererConfigurationBasics(net.pms.test.formats.FormatRecognitionTest) Time elapsed: 0 sec <<< ERROR!
testPlaystationImageGifCompatibility(net.pms.test.formats.FormatRecognitionTest) Time elapsed: 0.001 sec <<< ERROR!
testPlaystationVideoMkvCompatibility(net.pms.test.formats.FormatRecognitionTest) Time elapsed: 0 sec <<< ERROR!
testVirtualVideoActionInitializationCompatibility(net.pms.test.formats.FormatRecognitionTest) Time elapsed: 0 sec <<< ERROR!
testBackwardsCompatibility(net.pms.test.formats.FormatRecognitionTest) Time elapsed: 0.002 sec <<< ERROR!
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec - in net.pms.test.Iso639Test
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.011 sec - in net.pms.test.TaskRunnerTest
Tests run: 27, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.05 sec - in net.pms.util.FileUtilTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.051 sec - in net.pms.util.PlayerUtilTest
Results :
Tests in error:
FormatRecognitionTest.testBackwardsCompatibility » NoClassDefFound Could not i...
FormatRecognitionTest.testPlaystationAudioMp3Compatibility » NoClassDefFound C...
FormatRecognitionTest.testPlaystationImageGifCompatibility » NoClassDefFound C...
FormatRecognitionTest.testPlaystationImagePngCompatibility » NoClassDefFound C...
FormatRecognitionTest.testPlaystationImageTiffCompatibility » ExceptionInInitializer
FormatRecognitionTest.testPlaystationVideoMkvCompatibility » NoClassDefFound C...
FormatRecognitionTest.testPlaystationVideoMpgCompatibility » NoClassDefFound C...
FormatRecognitionTest.testRendererConfigurationBasics » NoClassDefFound Could ...
FormatRecognitionTest.testVirtualVideoActionInitializationCompatibility » NoClassDefFound
Tests run: 117, Failures: 0, Errors: 9, Skipped: 0
BUILD FAILURE
Total time: 28.340s
Finished at: Fri May 29 08:46:56 EDT 2015
Final Memory: 22M/408M
-> [Help 1]
Samsung UN55C8000
Samsung UN55C8000
Re: What broke?
Wait over - seems to be stable again.michaelt wrote:Is the backing tree broke?
Is there a thread or location, here or elsewhere which shows the status of the build environment?
It would help a lot for those building to avoid wasting time when the problem is not theirs.
Also: note the size difference between the 'standard' ffmpeg and the local built:
-rwxr-xr-x 1 umsmkv staff 30973172 May 30 02:59 ./target/bin/osx/ffmpeg
-rwxr-xr-x 1 sysadmin admin 15794964 May 23 17:37 ffmpeg-x3
Samsung UN55C8000
Samsung UN55C8000
