UMS 2.0.0 not appearing on Xbox 360
Re: UMS 2.0.0 not appearing on Xbox 360
Hmm.. it says you have one of theese DirectTV HR:
http://www.zatznotfunny.com/wordpress/w ... 0-2501.jpg
It does not find any xbox.
Edit: Pasetbin, ok. - tip: If you zip your logfile, you can attach it to the post here on forum.
I dont' know why it does not see your xbox..i'm sorry, you'll have to see if SubJunk or someone can shed light on this.
Edit2: Maybe you can force render to be xbox? (under general configuration tab, i think)
Yeah since it does not find the xbox i'm confused because it was working before.
Sorry for bump/double post but I am unable to ping the xbox. I was pinging the wrong ip.
If your computer can't ping the Xbox then yeah, UMS can't either. It may be a router setting or something
he can ping it ^^taiyga wrote:I can ping the ip of my xbox from my pc.
Here is the debug.log on pastebin
http://pastebin.com/qxnGaMRV
I actually updated saying I can't. It worked before, I don't know what changed as DMZ host is on so it should accept connections.squadjot wrote:he can ping it ^^taiyga wrote:I can ping the ip of my xbox from my pc.
