2.4.0 CUE file error - java exception
Sami32
Re: 2.4.0 CUE file error
Post by Sami32 »
Just click and download this links. After you can install one and test and so on until you find one working version and give us feedback ;)
UMS 4.2.2:
https://sourceforge.net/projects/unimed ... e/download
UMS 4.3.0:
UMS 5.2.3:
UMS 5.3.0:
As i never used CUE myself i'm not really aware about it, but did you get issue with others kind of playlist like .m38u or .m3u ?
IdPezzo
Re: 2.4.0 CUE file error - java exception
Post by IdPezzo »
Each one is tested. No success. :(
I have no .m3u or .m38u. Flac music comes vith cue.
My FiiO 3 music player plays cue without any trouble, and Foobar and VLC Player, too.
Other idea?
IdPezzo
Post by IdPezzo »
Sami32 wrote:Could you send me your .cue file ?
Loaded up a .flac and the belonging .cue to dropbox:
https://www.dropbox.com/s/2haasv49kkcw8q7/CD.zip?dl=0
Hope, you can find solution.
Sami32
Post by Sami32 »
It's look that i need to create an account before beeing able to download your file...
Could you just post here your .cue only, rename it with a .txt extension.
As it's just for check how your file is formed.
IdPezzo
Post by IdPezzo »
Sami32 wrote:It's look that i need to create an account before beeing able to download your file...
As it's just for check as you file is formed.
Sending...
George Enescu - Orchestral Works Vol. 2.txt
(772 Bytes) Downloaded 577 times
IdPezzo
Post by IdPezzo »
Hi, no solution regarding cue?
