2.4.0 CUE file error - java exception
I was just testing the new version concerning playing lossless FLACs with a .cue file - in 2.4.0 the CUE folder is not being read at all. I tried several cue files, the contents could not be shown within the "folder" (the .cue is presented as a folder in the file browser).
I see several exceptions in the log, full is in attach:
Please check what is going on - listening to FLACs (many of them in one image with a .cue file) is becoming another primary action for me while using UMS - apart from video with subs.
Thank you in advance for any help.
INFO 2013-02-11 21:37:51.885 [pool-83-thread-1] Exception in thread "pool-83-thread-1" java.lang.NullPointerException
INFO 2013-02-11 21:37:51.892 [pool-83-thread-1] at net.pms.dlna.CueFolder.resolve(CueFolder.java:99)
INFO 2013-02-11 21:37:51.893 [pool-83-thread-1] at net.pms.dlna.DLNAResource.run(DLNAResource.java:830)
INFO 2013-02-11 21:37:51.894 [pool-83-thread-1] at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO 2013-02-11 21:37:51.895 [pool-83-thread-1] at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO 2013-02-11 21:37:51.896 [pool-83-thread-1] at java.lang.Thread.run(Unknown Source)
- (14.15 KiB) Downloaded 745 times
Re: 2.4.0 CUE file error - java exception
Please, someone to look at this?
All best.
All best.
I have also problem with cue files:
Track can be seen, starts to play first track, than shows second track, but plays the first again. If the length of the second track is longer, than that of the first, starts to play the beginning of second track in the remaining time, then shows the third track, but really starts to play again the first one. Strange and annoying.
Can anybody help?
Reinstalled UMS, just testing...
Can anybody help?
Please follow instructions written in red above and provide the .log in the TRACE mode.
Attaching debug file.
The same problem with APE cue files.
Just remembering the problem: All track appear under cue, but only the first track is repeated, but shows 2nd, 3rd etc. tracks. (If the length of the track actually displayed is shorter, than the first track, the repeated playing of the first track stops earlier, and starts to repeat ubder the number of the next track ... and so on.). If I start another track (not the first one), always the first track is played.
- (102.51 KiB) Downloaded 651 times
FLAC/APE in CUE files play only the first track
Hi IdPezzo,
Do you have also this issue with UMS 4.2.2/4.3.0 and eventually 5.2.3/5.3.0 ?
You can find them there: https://sourceforge.net/projects/unimed ... s/Windows/
It's for debugging purpose, as it could be related to this old commit:
https://github.com/UniversalMediaServer ... 41b099bf87
Do you get this issue only for FLAC and APE files ?
IdPezzo your renderer is not properly recognized. Try to use this conf and send the log.
Pioneer-BDP.conf
- (362 Bytes) Downloaded 828 times
Re: FLAC/APE in CUE files play only the first track
IdPezzo, try the @valib advice first, as that APE could be not supported by the default renderer.
And post a new TRACE log if any issue arise while using the @valib test renderer..
Valib, Sami32, inserting the Pioneer-BDP.conf, the problem hasn't been solved. Both with FLAC and APE cue always the first track is played, irrespectively of which track is started and which track is shown on the display.
I did not use earlier versions of UMS, I'm a noob.
I use only FLAC and APE music files (and DSF, but Pioneer BDP 170 has no DSF support), thus I don't know, if other file types are affected by this problem.
As regards
'It's for debugging purpose, as it could be related to this old commit:
https://github.com/UniversalMediaServer ... 41b099bf87'
I cannot understand, and don't know, what to do with it.
As regards
- (119.62 KiB) Downloaded 862 times
And I now tried UMS 5.3 - the same problem.
