Same device is shown twice
umserich
Re: Same device is shown twice
Post by umserich »
Hello Samy32,
I've installed Your latest conf-file. Result: Same as before.
Firts of all In "Staus" I see already two DMR-BCT750/755 devices and one Panasonic TV device.
Now I've made a new zip-file. That contains:
- Preferences of any device
- conf-file of any device
- Renderer choice
- latest log-file
In "renderer choise" You'll see I have now deactivated all possibilitys and only one activated (Panasonic TV). When I activat in Pansonic DMRBCT nothing change.
Is that now ok or what do You recommend?
UMS_1.zip
(173.54 KiB) Downloaded 401 times
umserich
Post by umserich »
Hello Samy32,
- Renderer choice
- latest log-file
UMS_1.zip
(173.54 KiB) Downloaded 405 times
Sami32
Post by Sami32 »
- In the "General configuration" tab, click on "Select renderers" and unselect "Panasonic" except your renderer
And select only your Panasonic DMRBCT renderer.
umserich
Post by umserich »
Hello Samy 32,
Yesterday I send a reply, but couldn't find it today. Therefore I try to send it again, clicked button "post reply" and was surprised to find my post and Your answer under the reply window (strange).
In your reply you showed a few screenshots and I saw I activated the wrong renderer. But please be informed the proposal You made I also have tried. In this case I'll see two differend icons (see attachment), but the same device twice as before (DMR-BCT750/755). Also my TV is showed as "unknown DLNA client".
But the main thing is: Why I can't see my and Your post? This need help and shoud be cleared up before.
UMS dopelte Anzeige von Gerät_5.png (20.8 KiB) Viewed 9244 times
Sami32
Post by Sami32 »
It's fine from my side, so i don't know what's happen to you. I was just surprised that you posted 2 times the same.
BTW, it seem you forgotten to post your log, a picture only do not really help much for debugging...
umserich
Post by umserich »
Hello Samy32,
appologize for the meantime and coming back to Your last post.
I haven't realised "page 2". That was the reason not find my post.
By the way. Te last picture I send shows, I still have two diiferend icons for the same device (DMR-BCT750/755). Activating in "Select renderers/Panasonic" TV too, I get two same ions but still two same devices (DMR-BCT750/755). This is what I can't understand, because I really have only one of them.
Sami32
Post by Sami32 »
Hello umserich,
As asked, i need your new log.
You can try with that renderer:
Panasonic-DMR2.conf
(1.95 KiB) Downloaded 514 times
umserich
Post by umserich »
Hello Samy32,
please find attached a new screenshot what symbols UMS shoes and the *.zip-file, created with that *.conf-file You send.
ums_dbg_3.zip
(27.65 KiB) Downloaded 471 times
UMS dopelte Anzeige von Gerät_6.png (25.66 KiB) Viewed 9183 times
Sami32
Post by Sami32 »
Hi umserich,
As you can see yourself, one thumbnail is for the player/renderer and the second one for the recorder/server; it's how your renderer announce itself on the network.
OK, i hope that this renderer will be fine this time ;)
Panasonic-DMR2.conf
(1.92 KiB) Downloaded 481 times
Please, take time to return feedback.
umserich
Post by umserich »
Hello Samy32,
I think we should stay with that situation at this time.
Thanks a lot for Your time and Your informations.
