Version 5.1.0 is released
hasimirrossi
Re: Version 5.1.0 is released
Post by hasimirrossi »
Rocket wrote:Unable to view video files using a x360, brings up options for image browsing instead.
Still? Bah. Looks like I'm sticking with 4.4.0 then.
Lassik
Post by Lassik »
***UPDATE***
DISREGARD. I started looking through the support forums which is what I should have done in the first place (my bad) and I found that my concern was already addressed.
Thread: viewtopic.php?f=9&t=3113&start=10
Link to version that works fine: http://www.spirton.com/uploads/UMS/UMS-30f0f20.exe
***UPDATE***
I was on version 4.4.0 and finally decided to update to this version. Now i'm having issues with "File type not supported" on my TV.
I have a Samsung UN55D7000LF.
UMS is currently running on a Windows 7 machine that is running Java 8. I have tried both the Java 7 and Java 8 versions of UMS with the same results. I went back and installed versions 5.0.0 and 5.0.1 and the same thing happened. So it appears this issue began after the update from 4.4.0 to 5.0.0.
I went back and installed 4.4.0 and it's working fine again. All files play with no issues. When installing, I choose clean install every time and I don't touch any of the settings. Everything is default.
If this helps, here are all the details about the file i'm trying to play. It's an MP4 file format.
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : [email protected]
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 4 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 1h 44mn
Bit rate                                 : 4 778 Kbps
Width                                    : 1 280 pixels
Height                                   : 536 pixels
Display aspect ratio                     : 2.40:1
Frame rate mode                          : Constant
Frame rate                               : 25.000 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.279
Stream size                              : 3.47 GiB (95%)
Writing library                          : x264 core 144 r2525M 40bb568
Encoding settings                        : cabac=1 / ref=4 / deblock=1:0:0 /
  analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 /
  me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 /
  fast_pskip=1 / chroma_qp_offset=-3 / threads=40 / lookahead_threads=8 /
  sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 /
  constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3
  / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40
  / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.60
  / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : 40
Duration                                 : 1h 44mn
Bit rate mode                            : Constant
Bit rate                                 : 224 Kbps
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 48.0 KHz
Compression mode                         : Lossy
Stream size                              : 167 MiB (4%)
Language                                 : unk
When I got this problem I just ignore it and enter the first folder and it works like normal. It seems like the Xbox has a bug that interferes with our new 5.0 network stuff and we are working a workaround.
Yeah it seems to be a thing with Microsoft products
Forceflow
Post by Forceflow »
Revan wrote:Since the new Version, Video transcoding (mkv) issnt working anymore. It seems the cause is ffmpeg64.exe.
The only thing by getting it working again is renaming ffmpeg.exe to ffmpeg64.exe! How can i use 64bit transcoding? And ofc i've a x64 OS. The log issnt showing anything useful.
I'm having this same problem - searched the log as well. I'm on Win 8.1 x64.
Thanks for the solution though, something wrong with that ffmpeg64 executable.
Update: executable just seems to fail silently, while the renamed ffmpeg (the 32-bit one) keeps running.
If you could make a support thread for this with logs then we can work on fixing it :)
Forceflow
Post by Forceflow »
Okay, did that here: viewtopic.php?f=9&t=3216
Sorry for polluting this thread and thanks for all the hard work.
jps92
Post by jps92 »
With a Bravia EX the subtitling doesn't work anymore with one mkv :
Format : UTF-8
Identifiant du codec : S_TEXT/UTF8
Identifiant du codec/Info : UTF-8 Plain Text
Titre : French Forced
Langue : frf
Default : Oui
Forced : Oui
Berzerk
Post by Berzerk »
Same problem here, subtitles are not rendered. (PS3 - Toshiba TV & Samsung F9000)
Only the first 3 are rendered, then, no more subtitles at all.
MediaInfo:
General
Unique ID                   : 253086762168607131041560317583109534206 (0xBE66BCC4DC4AE0A191E0D7BDC08A31FE)
Complete name               : X:\Al mijn Louis de Funes DVDs (2012-03-20) ENCODED\La Zizanie (1978)\La Zizanie.mkv
Format                      : Matroska
Format version              : Version 4 / Version 2
File size                   : 758 MiB
Duration                    : 1h 32mn
Overall bit rate            : 1 147 Kbps
Encoded date                : UTC 2013-03-09 04:00:20
Writing application         : mkvmerge v6.1.0 ('Old Devil') built on Mar  2 2013 14:32:37
Writing library             : libebml v1.3.0 + libmatroska v1.4.0
Video
Format                      : AVC
Format settings, ReFrames   : 16 frames
Codec ID                    : V_MPEG4/ISO/AVC
Duration                    : 1h 32mn
Bit rate                    : 932 Kbps
Width                       : 720 pixels
Height                      : 432 pixels
Original display aspect rat : 2.40:1
Color space                 : YUV
Bit depth                   : 8 bits
Bits/(Pixel*Frame)          : 0.120
Stream size                 : 616 MiB (81%)
Writing library             : x264 core 130 r2273 b3065e6
Encoding settings           : cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=21.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=31250 / vbv_bufsize=31250 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Default                     : Yes
Forced                      : No
Audio
Format                      : AC-3
Format/Info                 : Audio Coding 3
Mode extension              : CM (complete main)
Codec ID                    : A_AC3
Duration                    : 1h 32mn
Bit rate                    : 192 Kbps
Bit depth                   : 16 bits
Stream size                 : 127 MiB (17%)
Language                    : French
Default                     : Yes
Forced                      : No
Text
Format                      : UTF-8
Codec ID                    : S_TEXT/UTF8
Codec ID/Info               : UTF-8 Plain Text
Language                    : Dutch
Default                     : Yes
Forced                      : No
UPDATE : unchecking "Defer to MEncoder when transcoding subtitles" in FFmpeg settings FIXED this from happening.
Please, anyone able to reproduce ? Any developer willing to look into this ?
jps92
Post by jps92 »
I've already unchecked "Defer to MEncoder when transcoding subtitles".
