Version 5.1.0 is released
General:
This release adds 64-bit transcoding, saves settings automatically, improves speed in several ways, fixes bugs and more!
Changes since 5.0.1:
  • General:
    • Added 64-bit versions of FFmpeg for a ~10% increase in transcoding speed
    • Removed the "Save" button since changes to settings are now saved automatically
    • Improved detection of playback states
    • Improved connection awareness
    • Improved True Motion frame interpolation speed by up to 20%
    • Improved folder population speed
    • Improved support for 3GPP files
    • Improved descriptions of settings
    • Slightly altered the memory usage bar
    • Fixed the renderer SeekByTime setting
    • Fixed renderer detection and recognition in some cases
    • Fixed display names for videos that have the Track (song title) value set
    • Fixed incorrect ContentFeatures headers being sent to renderers (thanks, master-nevi!)
    • Fixed the web logviewer
    • Fixed bugs with 3D subtitles
    • Fixed the setting for using embedded subtitles styles
  • Renderers:
    • Fixed filename bug on Sony Bravia TVs
    • Improved support for LG LED-backlit LCD 2014 TVs
    • Improved support for Samsung H6203 TVs
  • Languages:
    • Made more strings translatable
    • Updated Czech translation
    • Updated Dutch translation (thanks, ler0y!)
    • Updated French translation (thanks, Kirvx!)
    • Updated Italian translation (thanks, bartsimp!)
  • External Components:
    • Updated Chromecast Java API to 0.0.6
    • Updated Commons Codec to 1.10
    • Updated FEST Util to 1.2.5
    • Updated FFmpeg for Windows and OS X, which:
      • Improved support for many containers and codecs
      • Fixed bugs
    • Updated Gson to 2.3.1
    • Updated h2database to 1.4.186, which:
      • Fixed memory issues
      • Fixed caching issues
    • Updated InterFrame to 2.8.0, which:
      • Increased processing speed by up to 20%
      • Reduced memory use
      • Reduced dependencies
    • Updated JDom to 2.0.2
    • Updated JUnit to 4.12
    • Updated Plexus Utils to 3.0.21
    • Updated slf4j to 1.7.10
Madoka
Re: Version 5.1.0 is released
Post by Madoka »
Thanks for the new release! Been trying the nightlies, and it's been great so far. Love the 64-bit transcoding.
Cheers Madoka, and thanks for your help with it!
Renegade
Post by Renegade »
with reference to this topic: viewtopic.php?f=5&t=3148
Problem solved in version 5.1.0 (audio work) but video stopped after few minutes and i can not fast forward the movie (in previus version 5.0.1 i can) :(
jorgehav
Post by jorgehav »
Great Server....... you guys work hard & round the clock.....by far the best server on the net (cross-platform included !!!)
Regards from Havana,
Jorge
Revan
Post by Revan »
Since the new Version, Video transcoding (mkv) issnt working anymore. It seems the cause is ffmpeg64.exe.
The only thing by getting it working again is renaming ffmpeg.exe to ffmpeg64.exe! How can i use 64bit transcoding? And ofc i've a x64 OS. The log issnt showing anything useful.
Rocket
Post by Rocket »
Unable to view video files using a x360, brings up options for image browsing instead.
michaelt
Post by michaelt »
Initial testing confirms repeat problem with filesystem access, usually on first launch or after renderer off overnight with UMS running:
  • title "M*A*S*H (MASH\ 1970\ Blu-ray).mkv" not parsed
    "Not Supported File Format" reported for all titles
This is the same as the 5.0.1 release.
See Support forum for logs.
. . . . and a few others.
Samsung UN55C8000
ExSport
Post by ExSport »
"\" is not acceptable char on Windows so I suppose it is hidden as UMS code can't handle with it (also in case you are on Linux)
michaelt
Post by michaelt »
ExSport wrote:"\" is not acceptable char on Windows so I suppose it is hidden as UMS code can't handle with it (also in case you are on Linux)
This only fails on the 'first' launch. If I quit & relaunch, it parses fine!
I am on OSX - '\' works fine in a filename. My problem is with the colon ':' character. In a filename slash '\' is translated to a colon ':' internally since slash is the filename separator character. Hence there is no way to have a colon ':' in a filename. I'll try changing it to a semicolon ';' and see if no one notices.
thanx
Samsung UN55C8000
