HT-J5500 won't show external subs
Re: HT-J5500 won't show external subs
As soon as I remove SubRip from the SupportedExternalSubtitlesFormats, the name of the file displayed changes (extension on the HT-J5500 goes from StreamingSub to External Sub) and the file simply stops playing after a few seconds.
In any case, that should work. The reason the file stops playing after a few seconds is the thing to worry about, and I'd have to ask you to submit a new debug log while trying to play a couple of different files with this configuration. It could simply be because the server hardware is to weak to transcode on the fly, so that the buffer runs low. Transcoding requires much more CPU than streaming does.
