[FIXED] Clean install 2.4.1 wont play h264 on BraviaW5500
ExSport
Re: Clean install 2.4.1 wont play h264 on BraviaW5500
Post by ExSport »
What does it means for your version? It should be stated in conf file what is used as default when not defined...
I made a test version for another Bravia user recently, maybe you can try it and post your results: http://www.spirton.com/uploads/UMS/UMS-Serenus-2.exe
<rant>It's so weird how Sony made a very flexible and great DLNA renderer with the PS3 but then all their TVs suck when it comes to DLNA. Must be completely different sub-companies that work on them. We spend so much time developing workarounds for Bravias</rant>
squadjot
Post by squadjot »
Hi Subjunk , ill test it!
<rant>why dont i get forum updates anymore??</rant>
squadjot
Post by squadjot »
OK, tested with out the box settings.. still not working,
Attaching logs, thanks alot
squadjot wrote:Hi Subjunk , ill test it!
Not sure why. They work for me. Maybe try turning notifications off then on
squadjot wrote:OK, tested with out the box settings.. still not working,
That log is from another version :)
squadjot
Post by squadjot »
OOps..****
Sorry here's the right one..
2013-Serenus2_2.zip
(22.99 KiB) Downloaded 611 times
Can you please make another debug.log, this time using version 2.4.2 and do the following:
Try to play it normally (the way that fails), then play it via the transcode folder with the srt option. Also please wait a few seconds between clicks on the TV since that should make the log timeline clearer.
Sorry for all the trouble but I don't have a Bravia so you are my eyes here :)
squadjot
Post by squadjot »
Ok, sure thing, i'll do what ever you tell me to ^_^
2013-Serenus2_3.zip
(31.69 KiB) Downloaded 650 times
squadjot wrote:i'll do what ever you tell me to ^_^
Such... POWER! lol looking at the log now
Just to make sure; in the test, it failed the first time and succeeded the second time, right?
