2.3.0 external subtitles (Sony Bravia 40EX650)
squadjot
Re: 2.3.0 external subtitles (Sony Bravia 40EX650)
Post by squadjot »
I'm also experiencing this on WD TV Live, i will report it soon - here
clapton wrote:works with Mencoder subrip and FFmpeg subrip only. rewinding is very slow as in PS3MS and it crashes in FFmpeg subrip.
dont understand why Mencoder External Subtitles dont work cause it works on PS3MS.
OK so it works via the transcode folder, that's great news. It means it is probably just a setting. Try going to the Transcoding Settings tab and choose the MEncoder section on the left. Then find the setting "Audio/subtitles language priority" and clear it so it is blank. Does that fix it?
clapton
Post by clapton »
no, its the same.
ExSport
Post by ExSport »
I am not sure if I understand right but it seems clapton problem is unique.
His log says renderer is unknows so no renderer conf is used but he said it is detected correctly...
Also in log there is only one mp4 file streamed (unknown renderer supports all formats by default?) so noone can expect subs. There is no info about MEncoder in log.
So writing "no, its the same" say nothing. Noone knows if he exactly did what was requested or there are other conflicting settings.
@clapton: Please after every change requested by developers please upload also your debug.zip (in TRACE mode) so we can check all the applied settings etc...
Thx
clapton
Post by clapton »
I did every little thing that u guys asked me to do.
(20.97 KiB) Downloaded 524 times
ExSport
Post by ExSport »
It is ok, you did, but when you do it, we need debug.zip 8-)
It is the first time I can see MEnocder was used in your log but you didn't set TRACE debug level so needed info is missing.
Anyway I see UMS tried to play file with subs. You didn't saw any subs???
DEBUG 2013-02-08 12:56:27.648 [mencoder.exe-13] Starting "C:\Program Files (x86)\Universal Media Server\win32\mencoder.exe" -ss 71.383 "D:\Downloads\Skyfall (2012)\Skyfall.2012.720p.BrRip.x264.YIFY.mp4" -msglevel statusline=2 -oac lavc -of mpeg -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 2 -lavdopts debug=0:threads=2 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=448:threads=2:keyint=5:vqscale=2:vqmin=3:vrc_maxrate=54000:vrc_buf_size=7000 -ass -ass-color ffffff00 -ass-border-color 00000000 -ass-font-scale 1.8 -font C:\Windows\Fonts\Arial.ttf -ass-force-style FontName=C:\Windows\Fonts\Arial.ttf,Outline=1,Shadow=1,MarginV=10 -noflip-hebrew -fontconfig -subcp cp1252 -nosub -sub "D:\Downloads\Skyfall (2012)\Skyfall.2012.720p.BrRip.x264.YIFY.srt" -ofps 24000/1001 -lavdopts fast -mc 0.1 -af lavcresample=48000 -srate 48000 -o \\.\pipe\mencoder1360324587535
Not sure is "-nosub" will override "-sub" param but I suppose subs should be visible (if subs are not broken).
clapton
Post by clapton »
subs are playin fine on the PC. in that folder I have 2 of them: one (named as movie file) in my native language and the other is in english.
I set the log to TRACE:
(91.27 KiB) Downloaded 544 times
ExSport
Post by ExSport »
UMS generates and starts this MEncoder command:
"C:\Program Files (x86)\Universal Media Server\win32\mencoder.exe" -ss 0 "D:\Downloads\Skyfall (2012)\Skyfall.2012.720p.BrRip.x264.YIFY.mp4" -msglevel statusline=2 -oac lavc -of mpeg -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 2 -lavdopts debug=0:threads=2 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=448:threads=2:keyint=5:vqscale=2:vqmin=3:vrc_maxrate=54000:vrc_buf_size=7000 -ass -ass-color ffffff00 -ass-border-color 00000000 -ass-font-scale 1.8 -font C:\Windows\Fonts\Arial.ttf -ass-force-style FontName=C:\Windows\Fonts\Arial.ttf,Outline=1,Shadow=1,MarginV=10 -noflip-hebrew -fontconfig -subcp cp1252 -nosub -sub "D:\Downloads\Skyfall (2012)\Skyfall.2012.720p.BrRip.x264.YIFY.srt" -ofps 24000/1001 -lavdopts fast -mc 0.1 -af lavcresample=48000 -srate 48000 -o testsubs.mpg
If you don't see subs, try starting this code directly on your PC outside UMS.
- start CMD
- paste code above
- in current dir file "testsubs.mpg" is generated. You don't need to transcode whole file so you can stop it via CTRL+C (check .srt file when 1st subs starts so your test file will be longer ;) )
- check them in any media player if you see burned subs.
- if not, try to do the same but without "-nosub" part in command line
- if no subs are rendered again, try to delete also "-ass" part
- if subs are still missing, post sample of your file (if possible) with subs file [D:\Downloads\Skyfall (2012)\Skyfall.2012.720p.BrRip.x264.YIFY.srt]
- also post Mencoder output if it will generate some strage errors
Thx
