Mkv and pany
Re: Mkv and pany
For details see Creating a custom device configuration in the wiki.Nadahar wrote:There's also a folder for renderer configurations under UMS' profile folder (where UMS.conf is) and this folder is writable by default. You're supposed to put your custom configurations there while the ones in %programfiles% are those that come as standard.
nickhere, I added a switch to turn off metadata on a per-renderer basis. Would you mind removing update.jar and pulling the latest snapshot and testing UMS with this line in your custom viera conf to confirm it works:
PushMetadata = false
Re: Mkv and pany
push meta data work for the transport
and video is still video/mpeg
While we are at debugging the panasonic
i decided to leave the setting video.mpeg and check the web setting you have
ted under ffmpeg cant read file error
mencoder works for ted
Your onion stream doesn't work on my tv or mytablet bubble dlna
- (527.87 KiB) Downloaded 410 times
Re: Mkv and pany
Do you come with a translator?
Re: Mkv and pany
NoNadahar wrote:Do you come with a translator?
That has not been program yet.
Not sure you can handle the job.
I just went thru the web setting
that what work and doesn't
Re: Mkv and pany
#PushMetadata = falseinfidel wrote:For details see Creating a custom device configuration in the wiki.Nadahar wrote:There's also a folder for renderer configurations under UMS' profile folder (where UMS.conf is) and this folder is writable by default. You're supposed to put your custom configurations there while the ones in %programfiles% are those that come as standard.
nickhere, I added a switch to turn off metadata on a per-renderer basis. Would you mind removing update.jar and pulling the latest snapshot and testing UMS with this line in your custom viera conf to confirm it works:Code: Select all
make jumpy kodi addon movie123 broken
also on jumpy you need to filter out the color information in the name
I also notice different renders can show a different number of lines should this be in the renders config file so you can hit left arrow or right arrow for next page
