Mkv and pany
Mkv and pany
mkv not parsing on my panny
i dl angie trebecca
the pilot episode work the second one didn't
They both work on townky
this is the beta6 b2
i dl angie trebecca
- (65.99 KiB) Downloaded 655 times
Re: Mkv and pany
I can't see that you've tried to play the non working file in the log. You have to reproduce the problem while making the log, that means to try to play the file that doesn't work so that we can see what's happening.
Also it would be helpful if you disabled jumpy while creating the debug file (just move the jumpy file out of the plugins folder temporarily).
Re: Mkv and pany
here the new dump
if you ever want to debug my tv set with me we can teamviewer i can hook a web cam to display my set while you do your thing
I also notice mecoder was never fixed for certain iso (no audio)
Please check the build this is nightly build from last night i think.
the mkv not parsing so it is hidden
would it be easier to put the file on dropbox so you can DL and test
did i mention the pany media player and twonky does play it
- (58.57 KiB) Downloaded 624 times
Re: Mkv and pany
the mkv that wont play
https://drive.google.com/file/d/0Bz8eKh ... sp=sharing
the iso for mencoder no sound
https://drive.google.com/open?id=0Bz8eK ... 2paRkhpb2s
Re: Mkv and pany
I was bored so i set media info to false
it read and play but skips
Re: Mkv and pany
The reason is clear:
I'm guessing it's a bad file, but we can try to investigate. Please install MediaInfo GUI (I'm linking to a version without installer since the installer has adware bundled). Open the file with MediaInfo, select "text view" (one of the icons on the left side) and copy and paste the content here (inside tags.
INFO 2016-01-30 09:49:47.093 [New I/O worker #16] The file Z:\Kodi\TV Shows\Angie trebecca\Angie.Tribeca.S01E02.1080p.HDTV.x264-SERIOUSLY[rarbg]\Angie.Tribeca.S01E02.1080p.HDTV.x264-SERIOUSLY.mkv could not be parsed. It will be hidden
[code]
Re: Mkv and pany
I would think so to.
if it didnt play on pany media server and twonky
but it does
but it does
Re: Mkv and pany
Say again? I didn't understand anything of that last post.
I'd like you to paste the result of MediaInfo's analysis of the problem file here. Is that something you can do?
Re: Mkv and pany
it played on the panny media player (built in to the tv set) and on twonky.
Twonky the media player i have on the mybook live
you can download the file above
but here the result
General
Unique ID : 192030740299977309739326552051979927300 (0x9077C679F90A9BC492C7DC21C8BC3F04)
Complete name : Z:\Kodi\TV Shows\Angie trebecca\Angie.Tribeca.S01E02.1080p.HDTV.x264-SERIOUSLY[rarbg]\Angie.Tribeca.S01E02.1080p.HDTV.x264-SERIOUSLY.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 905 MiB
Duration : 19mn 55s
Overall bit rate : 6 349 Kbps
Encoded date : UTC 2016-01-17 16:04:59
Writing application : mkvmerge v8.5.1 ('Where you lead I will follow') 32bit
Writing library : libebml v1.3.3 + libmatroska v1.4.4
Video
Format : AVC
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 19mn 55s
Bit rate : 6 031 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.116
Stream size : 859 MiB (95%)
Writing library : x264 core 148 r2638 7599210
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=9 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=17.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Color range : Limited
Matrix coefficients : BT.709
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 19mn 55s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Frame rate : 31.250 fps (1536 spf)
Compression mode : Lossy
Stream size : 27.4 MiB (3%)
Default : Yes
Forced : No
but here the result
General
Format : Matroska
File size : 905 MiB
Duration : 19mn 55s
Video
Format : AVC
Duration : 19mn 55s
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 19mn 55s
Bit rate : 192 Kbps
Default : Yes
Forced : No
Re: Mkv and pany
Ok, no obvious problem there. I'm downloading the files for testing, but it will take ages since my line is limited.
