Old videos not rendering
I doubt this is a bug, but I've attached the trace log anyway. Currently running Version 7.0.0-b2... Newer videos stream from my PC to my Bravia tv with no problems as they most always have, except for some occasional stuttering issues.
Recently had the desire to watch old family videos from when the kids were younger. The ones I converted from VHS tapes ages ago play fine, but we have tons of old low res/frame rate .AVI videos from an old point and shoot camera from 2004-2007 in particular that are just black on the tv with audio only. Not sure what more info you will need to possibly help... Looking at the properties, they are all 320x240 in size, and 15 fps. If my memory serves me correct, they were made from an Olympus p&s.
Would it be better to convert them all (hundreds of them) to some other format or is there something I can add or change to UMS?
Oh, and I am using the default UMS settings for a wireless connection to the tv.
- (227.86 KiB) Downloaded 318 times
Re: Old videos not rendering
Please, could copy / paste the MediaInfo log of your 2004-jonathansroomjanuary1.avi file ?
As it's not recognized by UMS. With your MediaInfo log we could make it happen.
I suspect these AVI, as i think your others AVI files play fine ?, have a too low resolution and/or frame rate for your renderer support. That's said we should be able to make it play.
Before i will need that you run this command line and post this little sample of 7s here (replace the AVI link by any video of your choice).
Thank you for your understanding.
ffmpeg64.exe -y -loglevel info -i "D:\media\family vids\2007 videos\2007.10.31-aiden.avi" -t 7 -filter_complex "pad=max(iw\,ih*16/9):max(ih\,iw/16*9):(ow-iw)/2:(oh-ih)/2, setdar=4/3" -bufsize 1835k -maxrate 14000k -g 5 -q:v 1 -qmin 2 -qmax 3 -ab 640k -ar 48000 -c:a ac3 -c:v mpeg2video -f vob umstest.vob
As the resolution of your videos are too small, you should try to add this line into your renderer configuration file:
And / or
RescaleByRenderer = false
CustomFFmpegOptions = -r 25
Thanks for the replies.
A bit daunting with my limited skills so got intimidated the first time I checked the thread, but will try to figure this out and report back.
Will these settings mess with other normal/better quality videos?Sami32 wrote:As the resolution of your videos are too small, you should try to add this line into your renderer configuration file:And / orCode: Select all
Sorry, i guess that i should explained more
You can use that UMS version: (replace the original one by this ums.jar, into your UMS's program folder)
https://we.tl/XrmmRUlZ2V (valid for 7 days)
If that make things more easy for you, use this already modified renderer's configuration file: (with some more changes) Replace the original one by that one.
Run a new AVIs test with FFmpeg video engine and report back with your new log attached.
After having installed MediaInfo, you just need to right-click on the AVI video and select MediaInfo. From there, you can save the log and post it here, or copy / paste the informations displayed and copy it here.
If you need more explainations, do not hesitate to ask.
When you'll have tested it, i'll give you an optimized renderer that should give you a much better quality display for your AVI family videos rendering.
