Version 3.0.0-a2 is released
General:
This improves transcoding quality, file support, multithreading support and fixes many bugs.
Download:
Windows
Linux
OS X - Coming Soon
Changes since 3.0.0-a1:
  • General:
    • Added manual configuration option (hide_subs_info) to hide subtitle info from filenames while browsing
    • FFmpeg starts faster
    • Improved quality of H.264 transcoding by default
    • Added H.264 transcoding quality option
    • Improved speed of list population, though initial folder may be slower
    • VLC video no longer loops
    • Added multithreading support to VLC
    • Audio files are added to the transcode folder
    • Chapter folders are hidden if the video duration is less than the chapter length
    • Improved file compatibility detection for H.264 muxing
    • Renamed a lot of configuration variables
    • Added thumbnail support to Samsung 2012 ES and EH models (thanks, dmitche3!)
    • Removed the obsolete MPlayerAudio, MPlayerWebAudio and MPlayerWebVideoDump engines
    • Fixed startup issue on OS X
    • Fixed RAW image transcoding and support 28 additional RAW file extensions
    • Fixed incorrect server IP address when starting UMS by launching UMS.exe or UMS.bat
    • Fixed layout issues
    • Fixed various bugs
  • Languages:
    • Updated Dutch translation (thanks, Leroy!)
  • External Components:
    • Updated FFmpeg on all operating systems, which:
      • Improves ASS/SSA subtitle support
      • Improves handling of aspect ratios, even when muxing
      • Fixes multithreaded MPEG-4 decoding
      • Added multithreading to ALAC decoding
      • Speeds up JPEG decoding
      • Fixes and improves MP3, AAC and DTS decoding stability
      • Fixes memory leaks
      • Fixes channel mapping with surround AAC audio
      • Improves H.264 and VC-1 support
      • Improves Vorbis support
      • Improves Matroska support
      • Improves MPEG-TS muxing
    • Updated MediaInfo for Windows to 0.7.63, which:
      • Adds H.265 (HEVC) support
      • Fixed some crashes with .mov files
      • Improved AVI support
    • Updated Netty to 3.6.6
    • Updated Thumbnailator to 0.4.4, which:
      • Fixes memory errors with the latest Java Runtimes
Upgrade Notes:
For all versions:
Some configuration options for 3.x are not compatible with the 2.x releases, and a lot of them were renamed between 3.0.0-a1 and 3.0.0-a2, so it may be wise to make a backup of your configuration before installing.
It is recommended (but usually not necessary) to delete your UMS.conf file prior to installing this version. Windows users can choose the "clean install" option while installing instead.
Wolfgan
Re: Version 3.0.0-a2 is released
Post by Wolfgan »
Thanks for the update!
robod
Post by robod »
Works nice! Thanks! :D
Tianuchka
Post by Tianuchka »
Doesn't work for me (((
There is a permanent error of DLNA protocol, code 2101 (not sure) appearing in the right upper corner of the PS3, while trying to browse the media folders :cry:
After coming back to the PC, the UMS shuts down without any error messages!
Never had such a problems ever before...
ExSport
Post by ExSport »
Log, log, log, log, log.....debut.log posted in correct category.
Sorry to see you're having problems, Tianuchka. I'll be happy to give you support in the support category of the forum :)
Tianuchka
Post by Tianuchka »
SubJunk wrote:Sorry to see you're having problems, Tianuchka. I'll be happy to give you support in the support category of the forum :)
Oh, no, thanx a lot! I will use a 3.0.0-a1 since it works beautiful for me )))
Sunwind
Post by Sunwind »
causes Java to crash when I try and browse folders. the log doesn't change so there's nothing to post. latest java update.
Sunwind wrote:causes Java to crash when I try and browse folders. the log doesn't change so there's nothing to post. latest java update.
Java should create a new file in the program's installation directory when it crashes, is it in there?
Sunwind
Post by Sunwind »
what's the file called? if it's debug.log then like I said nothing in that file changes, I don't think it gets a chance to write anything to it due to the crash.
It doesn't seem to be UMS that is crashing but Java itself. reinstalled alpha1 and runs fine again.
Congratulations!
You have the recommended Java installed (Version 7 Update 25).
