I am surprised no iso dvd audio
I came back to ums so i can have a media server that read iso dvd
you never fix the dvd audio on some dvd
sound is still muted
Re: I am surprised no iso dvd audio
If you start with reading the text in red above, we might get an idea of what your problem is.
i reported this on Fri Jan 23, 2015 i even provided a link to a iso that comes up with the audio muted. Gus i have to do it again and resupply the download
It's impossible for us (at least for me) to keep track of all the different issues and reports. If you could link to the previous thread it would help, I did a quick search through your posts but couldn't find it. We have done some fixes to DVD ISO playback, and I thought it was working fine now. I don't remember the exact issue with missing audio though.
If you can find the previous link to the ISO image that didn't work, I can download and test it. If it works for me but not for you, I'll need new debug files though. We have made significant changed to the log files produces in the 6.7.x versions, which makes logs produced with them much more useful for figuring out problems.
ok lets do that here the new link
https://drive.google.com/file/d/0Bz8eKh ... sp=sharing
Thank you for the sample. I've confirmed the problem and created an issue here. It seems to be a problem with MEncoder, which is the only transcoding engine we have that's capable of reading DVD ISOs. The project is more or less abandoned though, so if we can't find a workaround I doubt it will be fixed.
I'm not able to debug MEncoder, I know way to little about the code to even know where to start, not to mention that I don't even know how to build it (although I'm sure I could figure that out if spending enough time). SubJunk (the project owner) used to be a developer at MPlayer/MEncoder, so hopefully he can figure it out. Follow the GitHub issue if you want to track any progress.
Hello @nickhere,
Could you try to add these lines into your renderer's configuration file, and take the time to report feedback ?
or replace them by that one instead:
or
Note: I guess that you was not able to find your own issue ? as posting in it will have make it appear as that one, avoidind the opening of a duplicated one without all the log or explanation that was shared at that time.
DisableMencoderNoskip = true
CustomMencoderOptions = -mc 0
CustomMencoderOptions = -psprobe 10000
CustomMencoderOptions = -demuxer lavf
Give me sound but on another iso it plays too fast
Do we need to do a donation to get a log
As i cannot afford to download a such big file, and i wasn't even a part of the team at the time you've posted your issue...
1) So, the ISO with no sound worked correctly with "CustomMencoderOptions = -demuxer lavf" ?
2) Is that was your only ISO having no sound ?
3) Did you mean that all your others ISO play faster with that option, or only one ?
1 yes
2 no
3 other iso seem to skip even one with perfect sound
I will need some time to fiqure it out but some iso were compress from 8gb to 4gb
i will create a web server so you can download and test
2 no
