Bad sync sound track in transcode mode.
thora
Post by thora »
I use the last version of UMS and I've got bad synchro sound track (3 or 4 second late)
I tried to set the transcode buffer from 200 to 400 but the problem is still there.
Thank you for support.
(106.44 KiB) Downloaded 475 times
Sami32
Re: Bad sync sound track in transcode mode.
Post by Sami32 »
same same.
Go in the UMS "General Configuration" tab, select "Samsung 9 Series" in "Default renderer when automatic detection fails" and select "Force default renderer..."
After that, restart UMS and your issue should be solved.
Enjoy ;)
thora
Post by thora »
Hi Sami32,
Thanks for help.
I set UMS with the indicated values and restarted but the problem is always there.
It's ok when I watch it through the UMS web interface on computer (Transcode Movie) but not on my tv (sound is late about 2 or 3 seconds) .....
Sami32
Post by Sami32 »
Hi thora,
Please, post a new trace log reproducing the issue while the new renderer is used. Thanks.
And if possible one other when you play from the web interface.
thora
Post by thora »
Hi Sami32,
ums_dbg.zip --> Renderer
ums_dbg_Iweb --> Web interface
Thanks for help ;)
ums_dbg_Iweb.zip
(68.83 KiB) Downloaded 408 times
(133.68 KiB) Downloaded 395 times
Sami32
Post by Sami32 »
I'll check at your logs. Thanks.
Do you have this issue with only one file ? or all your videos ? or only with some formats ?
Sami32
Post by Sami32 »
Thanks.
Do you mind to tests some others renderer versions ? Replace the original one by each of these ones:
To avoid mixing them, it should be better to download one and test it and so on.
1)
Samsung-9series.conf
(4.13 KiB) Downloaded 469 times
2)
(4.13 KiB) Downloaded 472 times
3)
(4.14 KiB) Downloaded 475 times
thora
Post by thora »
Hi Sami32,
Sorry for late answer.....
I tried with the sixth rendered files but the problem is still there. This is happen with many files used in "transcode" mode.
I will for the moment use non transcoded file.
Thank you very much for your support.
