Stream to iPod Touch?
Is there a step-by-step instruction on how to connect the iPod Touch to UMS? It seems that it is supported yet, I couldn't find anything on it in the forums or the internets! Any help would be appreciated.
Re: Stream to iPod Touch?
If you just install UMS on your server or laptop, you should be just fine.
The default UMS delivery includes a file called AirPlayer.conf which will be installed in your renderers directory. This file will give you the streaming support you need for your iPod.
On your iPod you can install any DNLA compatible client application. Done.
Any suggestions for the DLNA clients? Free and paid?
Since I don't own any Apple product, I can't really suggest you a good client app.
But I'm sure you should be able to find something in the Apple AppStore? Any DNLA compatible client app should be good to go...
