Problems with UMS after reinstalling Win7
Experienced a HD failure that I couldn't restore from so I had to reinstall everything. I reinstalled Win 7, and finally UMS 2.6.5. Went to go play a video file and it took about 2 minutes to load and then stuttering. I tried with other files and nothing. I have no idea what changed after reinstalling it but for some reason I can't get it to work now, when it was working flawlessly before.
Network:
100Mbit Ethernet from PC to Switch to 200Mbit EoP to Ethernet Switch that feeds PS3 and Smart TV. Neither the PS3 or the TV can play files without stuttering. Again, before I was able to play all my video files (re-encoded with handbrake) with no issues what so ever.
I tried installing 3.0.0 a2 after doing some reading it and change the bandwidth settings to wireless and it still has no effect. I even made sure that the PC's NIC is set to 100Mbit Full Duplex instead of Auto.
Any other suggestions? I attached the debug log file.
Thank you in advance
Network:
- (54.63 KiB) Downloaded 335 times
Re: Problems with UMS after reinstalling Win7
Seems like i found the solution. Needed to turn off "Large send offload ipv4" in my NIC configuration. Maybe add this to the FAQ since i had to search other sites for it?
