LG LB5800-SB Subtitles with character
Neocazen
Post by Neocazen »
Hello everyone.
   I'm having a problem with subtitles.
   Searching the forum here, I discovered that adding the line
"RemoveTagsFromSRTSubtitles = false" would solve the character question. Partly to me, yes.
   What happens is the following:
    Only works perfect if I convert the encoding of the caption to 8859-1, with UTF-8 characters continue.
   Not that it's a problem (just convert), but I wish I did not have to.
   I set up a specific render for my TV, since none has adapted to it.
   I wish they could help me or implement UTF-8 encoding as a choice.
Adding my TV only has in options default subtitles and Korean
He used minidlna and this problem did not occur with subtitles.
    Thank you
(29.57 KiB) Downloaded 497 times
