Windows 10 + CoreAvc
Zalex
Post by Zalex »
Is there anyone with CoreAvc working in a Windows 10 x64!?
As you can see, the CoreAvc x64 version doesn't registers into my system but the x86 versions appears as installed and enabled.
I have an nVidia and I would like to use the CUDA technology.
I've seen some CoreAvc/GPU Accel posts here, but none of them have the enough info.
In some website I've read that it seems that CoreAvc doesn't work in W10 but nothing for sure.
Any fix / idea will be very grateful.
Thank you.
Lx
