[CLOSED] UMS 64bit Windows Install
Locked
glenrocks
Post by glenrocks »
Right now, UMS build installs as 32bit..can it be upgraded to 64 bit install? Pros or Cons?
maxideus
Re: UMS 64bit Windows Install
Post by maxideus »
64bit applications allow programmers to use larger integers and floating points to do more math. Perhaps the renderers can benefit from a 64bit version but probably not UMS itself.
Hi glenrocks, it's a good question but like maxideus said there would be no benefit. UMS itself is super fast already, it's just the engines that would benefit from 64-bitness.
In the next version (1.3.0) I have added 64-bit FFmpeg which is used automatically when a 64-bit version of Windows is detected.
glenrocks
Post by glenrocks »
Thanks SJ and Max.
Since I do not uninstall and overwrite old version with new, will UMS install overwrite w/ new 64bit ffmpeg? From the running ffmpeg process, it says 32bit (WOW64)
I decided to not add 64-bit FFmpeg because it was running into memory issues. Maybe in the future :)
Locked
