UMS on Western Digital Mybooklive
Yuli_35
Post by Yuli_35 »
Hello To all,
My question is quite simple.
Has anyone try to instal UMS on Western Digital Mybooklive ?
Western Digital Mybooklive implements an old version of Twonky Server. But I would like to know if there is a possibility to run UMS on such "light" device.
(I found a procedure to upgrade the MBL with the V7.x Twonky version, but this requires licence.... ).
What is the minimum requirement to run UMS.
It seems that we can run Serviio on the WD (see the link: http://wiki.serviio.org/doku.php?id=install_wd)
So I suspect it is possible to do the same with UMS....
Thanks for your help and support.
Cheers Yuli.
