Version 3.0.0-a5 is released
General:
This fixes a startup problem affecting some users
Download:
Windows
Linux
OS X
Changes since 3.0.0-a4:
Upgrade Notes:
For all versions:
Some configuration options for 3.x are not compatible with the 2.x releases, and a lot of them were renamed between 3.0.0-a1 and 3.0.0-a2, so it may be wise to make a backup of your configuration before installing.
It is recommended (but usually not necessary) to delete your UMS.conf file prior to installing this version. Windows users can choose the "clean install" option while installing instead.
Download:
Windows
Linux
OS X
- General:
- Fixed a startup problem affecting some users
Upgrade Notes:
For all versions:
Re: Version 3.0.0-a5 is released
Mencoder is not transcoding the 5.1 track. It only picks up the stereo track. 3.0.0-a3 transcoded the 5.1 on my OPPO 93. FFpeg picks up the 5.1 when transcoding fine. Bug?
Raker13, if it's an HBO show like Game of Thrones for example, it may not be a bug. The behaviour shouldn't have changed between a3 and a5 though so if it has changed with the same video file then feel free to post about it in our support section
Seems to work OK now (for some reason a4 wanted the JDK installed as well and not just the JRE it seems)
Thanks for the quick fix! Wolf
Error occure:Re: Version 3.0.0-a5 is released
Please help!
I can't start and use the program.
The two last versions of this wonderful program gives me an error under during the "log-in".
Here is the debug-sentences that maybe can expalin the error.
I assume it has something to do with Java? Please help...
DEBUG 2013-09-03 14:07:48.177 [main] Launching: win32/mplayer.exe
ERROR 2013-09-03 14:08:48.200 [main] A serious error occurred during PMS init
java.lang.IllegalThreadStateException: process has not exited
at java.lang.ProcessImpl.exitValue(Unknown Source) ~[na:1.7.0_25]
at net.pms.PMS.checkProcessExistence(PMS.java:255) [ums.jar:3.0.0-a5]
at net.pms.PMS.init(PMS.java:590) [ums.jar:3.0.0-a5]
at net.pms.PMS.createInstance(PMS.java:1033) [ums.jar:3.0.0-a5]
at net.pms.PMS.main(PMS.java:1129) [ums.jar:3.0.0-a5]
Sorry, no spam here, but the debug have some more information. It absolutely has something to so with Java, right? But I seems I have the latest Java installed? hmm..
09-03 14:29:52 Please wait while we check the MPlayer font cache, this can take a minute or so.
09-03 14:29:57 Finished checking the MPlayer font cache.
09-03 14:29:57 Found VLC version 2.0.8 at: C:\Program Files\VideoLAN\VLC\vlc.exe
09-03 14:29:57 Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
09-03 14:29:58 Found plugin: com.chocolatey.pmsencoder.Plugin
09-03 14:29:58 Exception in thread "main" java.lang.VerifyError: class com.chocolatey.pmsencoder.PMSEncoder overrides final method launchTranscode.(Ljava/lang/String;Lnet/pms/dlna/DLNAResource;Lnet/pms/dlna/DLNAMediaInfo;Lnet/pms/io/OutputParams;)Lnet/pms/io/ProcessWrapper;
09-03 14:29:58 at java.lang.ClassLoader.defineClass1(Native Method)
09-03 14:29:58 at java.lang.ClassLoader.defineClass(Unknown Source)
09-03 14:29:58 at java.security.SecureClassLoader.defineClass(Unknown Source)
09-03 14:29:58 at java.net.URLClassLoader.defineClass(Unknown Source)
09-03 14:29:58 at java.net.URLClassLoader.access$100(Unknown Source)
09-03 14:29:58 at java.net.URLClassLoader$1.run(Unknown Source)
09-03 14:29:58 at java.security.AccessController.doPrivileged(Native Method)
09-03 14:29:58 at java.net.URLClassLoader.findClass(Unknown Source)
09-03 14:29:58 at java.lang.ClassLoader.loadClass(Unknown Source)
09-03 14:29:58 at java.lang.Class.getDeclaredConstructors0(Native Method)
09-03 14:29:58 at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
09-03 14:29:58 at java.lang.Class.getConstructor0(Unknown Source)
09-03 14:29:58 at java.lang.Class.newInstance(Unknown Source)
09-03 14:29:58 at net.pms.external.ExternalFactory.instantiateEarlyListeners(ExternalFactory.java:419)
09-03 14:29:58 at net.pms.external.ExternalFactory.lookup(ExternalFactory.java:399)
09-03 14:29:58 at net.pms.PMS.init(PMS.java:658)
09-03 14:29:58 at net.pms.PMS.createInstance(PMS.java:1033)
09-03 14:29:58 at net.pms.PMS.main(PMS.java:1129)
It is an announcement thread not support thread
Can you please try this version, jontemyrra?
Subjunk,
I worked perfect!!!
I´m curious about what Went wrong..?
(Sorry I used the wrong thread for this!)
I worked perfect!!!
Just a quick question. Is play resume in full effect yet?
