Blu-Ray Sony UBP-X800 Connection Issue
I'm trying to connect my Sony UBP-X800 with UMS that runs on my PC.
UMS is shown on the Player but when I select I get a message that the server is still starting...However after waiting for a minute nothing happens.
In UMS weirdly the Blu-Ray Player is listed 3 times with the same IP:
Twice with automatically assigned Sony-Bluray.conf and once with no conf.
I created a conf for that entry myself based on the Sony-Bluray.conf.
Could someone help me out and check the traces?
Previously I had issues even finding the UMS via my smartphone but in the end I could fix it by setting correct firewall settings for java.
So assume that this should not be the root cause...
- (38.92 KiB) Downloaded 570 times
Re: Blu-Ray Sony UBP-X800 Connection Issue
You're using the MovieInfo plugin which hasn't been updated for years. Remove all plugins from the "plugins" folder and try again.
Thx for the hint.
I removed the plugin but no improvement so far.
Attached new log.
Attached new log.
- ums_dbg_new.zip
- (54.45 KiB) Downloaded 654 times
@Coneman Yes, your renderer add is the reason.
Delete the renderer's configuration file that you've created and edit the Sony-Bluray2013.conf one as following:
If your issue still stay, please, post a new trace log.
UpnpDetailsSearch = BDP-2013|BDP-2017
chromecast_extension = false
