Suddenly stopped working?
I'm using it on mac and trying to connect to my ps4, it was working perfectly fine earlier but now it no longer works, i didn't change any settings or tinker with anything so idk why it isnt working.
- (26.91 KiB) Downloaded 288 times
Re: Suddenly stopped working?
You have to tell us more, I can't see anything wrong in your log although I can't see any communication with anything but Google Chrome either. It might be a network/firewall problem. I see that you have a custom renderer configuration tied to an IP address in "/Users/jamessmith/Library/Application Support/UMS/renderers/PlayStation4-192.168.0.13.conf". That might not be a very good idea if you renderer gets a new IP address, but it doesn't explain why there's no communication at all.
Have you done any changes to your network (new router etc) lately or installed system updates or other software that might have enabled a firewall on the computer running UMS? If so, I'd start there.
I haven't installed or uninstalled anything since it last worked,
I'm now getting a "Port Blocked, Change it in the general configuration tab." error after i removed the ip address custom configuration
