UMS 3.0.0 a-5 upgrade issue
nomi2013
Post by nomi2013 »
I followed the steps to upgrade from 2.5.6 to 3.0.0 a5
a) delete my existing ums.conf (backup to other folder) install UMS 3.0.0 a-5 with clean install.
b) Start UMS get following error..I know other user also have this error but there was customized build by subjunk..was that change not incooperated with this latest version?
I am using jumpy latest version with ums 2.5.6 but trying to upgrade to 3.0.0 a-5
I revert back to 2.6.5 and its working fine..
The reason I want to swith beside users suggestion of its working great is that with existing 2.6.5 with jumpy lates version If its running for long time and I am trying to run the same channel which was working before sometime shows in pause state and some time gives "Video file cannot be player".. If I restart UMS and click on the same channel using jumpy its worked without issue..because of this issue I have to restart the UMS again.
THanks for all the help
Nomi
09-03 14:29:52 Please wait while we check the MPlayer font cache, this can take a minute or so.
09-03 14:29:57 Finished checking the MPlayer font cache.
09-03 14:29:57 Found VLC version 2.0.8 at: C:\Program Files\VideoLAN\VLC\vlc.exe
09-03 14:29:57 Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
09-03 14:29:58 Found plugin: com.chocolatey.pmsencoder.Plugin
09-03 14:29:58 Exception in thread "main" java.lang.VerifyError: class com.chocolatey.pmsencoder.PMSEncoder overrides final method launchTranscode.(Ljava/lang/String;Lnet/pms/dlna/DLNAResource;Lnet/pms/dlna/DLNAMediaInfo;Lnet/pms/io/OutputParams;)Lnet/pms/io/ProcessWrapper;
09-03 14:29:58 at java.lang.ClassLoader.defineClass1(Native Method)
09-03 14:29:58 at java.lang.ClassLoader.defineClass(Unknown Source)
09-03 14:29:58 at java.security.SecureClassLoader.defineClass(Unknown Source)
09-03 14:29:58 at java.net.URLClassLoader.defineClass(Unknown Source)
09-03 14:29:58 at java.net.URLClassLoader.access$100(Unknown Source)
09-03 14:29:58 at java.net.URLClassLoader$1.run(Unknown Source)
09-03 14:29:58 at java.security.AccessController.doPrivileged(Native Method)
09-03 14:29:58 at java.net.URLClassLoader.findClass(Unknown Source)
09-03 14:29:58 at java.lang.ClassLoader.loadClass(Unknown Source)
09-03 14:29:58 at java.lang.Class.getDeclaredConstructors0(Native Method)
09-03 14:29:58 at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
09-03 14:29:58 at java.lang.Class.getConstructor0(Unknown Source)
09-03 14:29:58 at java.lang.Class.newInstance(Unknown Source)
09-03 14:29:58 at net.pms.external.ExternalFactory.instantiateEarlyListeners(ExternalFactory.java:419)
09-03 14:29:58 at net.pms.external.ExternalFactory.lookup(ExternalFactory.java:399)
09-03 14:29:58 at net.pms.PMS.init(PMS.java:658)
09-03 14:29:58 at net.pms.PMS.createInstance(PMS.java:1033)
09-03 14:29:58 at net.pms.PMS.main(PMS.java:1129)
nomi2013
Re: UMS 3.0.0 a-5 upgrade issue
Post by nomi2013 »
sorry the link for customized build is at
viewtopic.php?f=3&t=1147
but not sure if I should install the customized build..
I also don't want to uninstall and starts from scratch by removing all the folders and stuff If upgrade with clean install (with UMS.conf of old 2.5.6 delete before new isntall)..
Optimus_prime
Post by Optimus_prime »
This maybe an issue with the Channels Plugin. Post a help topic in the Channels forum topic here
nomi2013
Post by nomi2013 »
Thanks optimus
Let me ask a question how its channel plugin issue when subjunk issue a custom build to another user for same issue?
I follow all the steps as mentioned to upgrade but didn't succeed and roll back to 2.6.5? I am not sure what I am missing..deleted UMS.conf from userdata folder..click "clean install" for UMS 3.0 setup but got error.
I wanted to go to upgrade to 3.0. a-5 because of other issues which might not be related to UMS itself like sound lag the video and if I close and open the channel again (XBMC jump latest plugin) its okay..sometime channel runs okay but after sometime go "files cannot be played" and see pause state..if I restart UMS again the same channel works okay..
Thanks for you help
Nomi
