Adding Network Drive to Shared Folders
I have a 1 TB USB drive connected to my Airport Extreme that I store movies on. Movies play fine if I transfer them to the Movies Folder on my iMac. Is there a way to play them directly from the USB Drive by adding the USB Drive to the Shared Folders? I can't find any posts on mapping a drive.
Thanks in advance.
Patrick
Thanks in advance.
Patrick
Re: Adding Network Drive to Shared Folders
Got it, if you add the USB drive to the desktop, you can then see it in the Desktop Folder and make the connection there.
Hi
How can add usb hdd drive on desktop?
