Internal Subtitles Transcode Option
Skylion
Post by Skylion »
I am trying to develop a config file for my lg BD390 Bluray player. The only problem is that while it supports several formats, it does not support internal subtitles. I look towards the config files and I was wondering if you could add a parameter for the config file that would force trans-code the file if internal subtitles were detected, possibly automatically embed subtitles, or rip the subtitles into an .srt file and stream them to the renderer. It would be a useful parameter for other renderers that have limited subtitle support.
Re: Internal Subtitles Transcode Option
This is already done by default :)
Skylion
Post by Skylion »
Oh, I see the problem. I was using the old Force Transcode/Force Stream Parameter to test out the config file. I assume this bypasses that feature? :D
